suprasport Posted December 24, 2005 Share Posted December 24, 2005 pretty certain i have an airlock, engine is overheating, blowing cold air. then will blow hot air for a while and temp will drop, then does it over again in a cycle. how do i bleed the system is there any easy way, read about people doing it but no one saying how Link to comment Share on other sites More sharing options...
SatSport Posted December 24, 2005 Share Posted December 24, 2005 pos. blocked heater matrix?? Link to comment Share on other sites More sharing options...
bedlam Posted December 24, 2005 Share Posted December 24, 2005 K Car cold,take the rad cap off and start the car, switch the blower on to full and heater onto full, get yourself a nice big jug for adding the water into the rad. keep the car running at a fast idle and eventually the thermostat will open and thats when the water will be cicurlating fully, you will start to get bubbles (this is AIR) coming outta the top of the rad just keep adding water in and eventually you will remove the airlock. it takes a while to get the airlock out,keep checking the heat from the airvents and they will eventually go very hot. And be careful as doing this can get you a nasty burn. Replace rad cap and check expansion tank and take car for a run and check levels later . Andy Link to comment Share on other sites More sharing options...
Pig Posted December 24, 2005 Share Posted December 24, 2005 Nice one andy. Dont have a prob with this but a very detailed and helpful walkthrough Oh....just to be picky, how do you take the rad cap off twice Link to comment Share on other sites More sharing options...
bedlam Posted December 24, 2005 Share Posted December 24, 2005 you take it off...put it back on and then take it back off again..and then you say GROUNDHOG DAY IS HERE!! . Link to comment Share on other sites More sharing options...
Fifty Posted December 24, 2005 Share Posted December 24, 2005 great movie..watching it now..and tomorrow and the next day 52 Link to comment Share on other sites More sharing options...
suprasport Posted December 25, 2005 Author Share Posted December 25, 2005 thanks bedlam much appreciated Link to comment Share on other sites More sharing options...
