overheating
suprasport
K
Car cold,take the rad cap off and start the car, switch the blower on to full and heater onto full, get yourself a nice big jug for adding the water into the rad.
keep the car running at a fast idle and eventually the thermostat will open and thats when the water will be cicurlating fully, you will start to get bubbles (this is AIR) coming outta the top of the rad just keep adding water in and eventually you will remove the airlock.
it takes a while to get the airlock out,keep checking the heat from the airvents and they will eventually go very hot.
And be careful as doing this can get you a nasty burn.
Replace rad cap and check expansion tank and take car for a run and check levels later .
Andy
