merckx Posted December 24, 2005 Share Posted December 24, 2005 Just fitted my new CW SMIC , the car is performing great with plenty of power. But the boost has dropped from peaking at just over 1.2 bar to now just over 1 bar. What causes this, is it a less restrictive core with the air flow increasing through it. Or is it a more efficient intercooler with cooler charge temps? Does this indicate things are working better? Link to comment Share on other sites More sharing options...
merckx Posted December 25, 2005 Author Share Posted December 25, 2005 Anyone ? Link to comment Share on other sites More sharing options...
Pete Posted December 25, 2005 Share Posted December 25, 2005 Sure there's no leaks or bad seals? (Just a guess, I've not idea why this would be so) Link to comment Share on other sites More sharing options...
b_have Posted December 25, 2005 Share Posted December 25, 2005 Should be the opposite. I had to reduce duty cycle on the avcr to lower the boost after fitting my fmic. Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 25, 2005 Share Posted December 25, 2005 The boost shouldn't drop, triple check there are no hose or connector leaks. The IC will cool better than a stock one, so the colder, denser air the engine now sees should raise power at any given boost pressure. Link to comment Share on other sites More sharing options...
Pete Posted December 25, 2005 Share Posted December 25, 2005 The boost shouldn't drop, triple check there are no hose or connector leaks. Looks like I was on the right tracks then. :D Link to comment Share on other sites More sharing options...
merckx Posted December 25, 2005 Author Share Posted December 25, 2005 The boost shouldn't drop Bugger! Looks like I was on the right tracks then. :D Yep! I did make sure the connections on the intercooler were snug and tight, I would be surprised if they were leaking! Is it possible to pressurise the system and see if it maintains it, see what I can do tomorrow. Link to comment Share on other sites More sharing options...
mr keef Posted December 26, 2005 Share Posted December 26, 2005 I had exacly the same thing..i fitted a front mount intercooler.i was running 15psi and the boost dropped to 10psi,but the car felt a lot quicker!,checked all the hoses etc everything seemed ok,i have since taken the car to a garage,and they said the same everything looks fine! Link to comment Share on other sites More sharing options...
heckler Posted December 26, 2005 Share Posted December 26, 2005 I had exacly the same thing..i fitted a front mount intercooler.i was running 15psi and the boost dropped to 10psi,but the car felt a lot quicker!,checked all the hoses etc everything seemed ok,i have since taken the car to a garage,and they said the same everything looks fine! Same here! Link to comment Share on other sites More sharing options...
merckx Posted December 26, 2005 Author Share Posted December 26, 2005 I had exacly the same thing..i fitted a front mount intercooler.i was running 15psi and the boost dropped to 10psi,but the car felt a lot quicker!,checked all the hoses etc everything seemed ok,i have since taken the car to a garage,and they said the same everything looks fine! Thanks for that. Same here! I only removed the pipes connecting to the intercooler. But just to be sure I might disconnect the inlet pipe that goes down to the intercooler and the one that goes into the throttle body in order to pressure test that section. Thought about getting a rubber inner tube say about 3" in diameter, cutting it to make a long tube and then securing it to the pipe work in the engine bay and then using the valve to pump it up to say 1.2 bar to see if it maintains the pressure. I might need some duct tape wrapped around the tube though to stop it fom over inflating. Link to comment Share on other sites More sharing options...
bignum Posted December 26, 2005 Share Posted December 26, 2005 Hi ,i fitted 1 of these baby,s and im now hitting fuel cut,so it defo sounds like you have a leak somewhere,fiddly job though innit. Link to comment Share on other sites More sharing options...
Need4Speed Posted December 26, 2005 Share Posted December 26, 2005 Are you reading a gauge with a peak hold function? I lost all my boost spiking with one of these SMICs. Link to comment Share on other sites More sharing options...
merckx Posted December 26, 2005 Author Share Posted December 26, 2005 Are you reading a gauge with a peak hold function? I lost all my boost spiking with one of these SMICs. I've got a Defi 2 control unit so you can look at the peak value and also record the boost levels. I went out for a drive earlier, I did get it to go upto 1.2 bar once but tried again and it it would only just go past 1.0 bar. There's plenty of power there and it's accelerating great. Sometimes you can become paranoid and look for problems, I'll have another drive tomorrow. Link to comment Share on other sites More sharing options...
Need4Speed Posted December 27, 2005 Share Posted December 27, 2005 Turn it up then! Link to comment Share on other sites More sharing options...
