SupraStar 3000 Posted December 23, 2005 Share Posted December 23, 2005 Ive heard the horror stories of painted calipers / pin removal and need alittle info before changing pads on front and packs of my NA J-spec. Where is the pin located and is it only accessible from behind after removing the mounting bolt(s) (is it one ot two bolts each caliper)? all info appreciated Quote Link to comment Share on other sites More sharing options...
carl0s Posted December 23, 2005 Share Posted December 23, 2005 Ive heard the horror stories of painted calipers / pin removal and need alittle info before changing pads on front and packs of my NA J-spec. Where is the pin located and is it only accessible from behind after removing the mounting bolt(s) (is it one ot two bolts each caliper)? all info appreciated The pins have a head on the outside end, so can only be knocked out from behind, however this can be (and should be) done with the caliper in place. It's the first thing to do after removing the wheel. You'll need a hammer and some kind of punch. After punching it a bit, a 'brake pin removal tool' as sold in halfords (LASER range) would help as you'd be able to push that in and start knocking it. WD40 might help too. There are two pins (top and bottom) on each caliper btw. Quote Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted December 23, 2005 Author Share Posted December 23, 2005 thank you carl0s. Thats a BIG help. Much appreciated. Cheers mate Quote Link to comment Share on other sites More sharing options...
carl0s Posted December 23, 2005 Share Posted December 23, 2005 I had a philips screwdriver which after removing the red insulating plastic was a perfect fit for those holes i.e. great for knocking the pins all the way out, but I lost it Saw the removal pin/punch/whatevers today at Halfords but didn't buy one.. only £6.99 or so. They were 6mm.. not sure if that's the right size or not for our cars. Quote Link to comment Share on other sites More sharing options...
merckx Posted December 23, 2005 Share Posted December 23, 2005 I'm not totally familiar with the smaller J spec brake, but AFAIK know they don't have these pins that you knock out. I know the UK brakes do, they were a pain to remove on mine. From what I remember the pins were just over 6mm. Quote Link to comment Share on other sites More sharing options...
carl0s Posted December 23, 2005 Share Posted December 23, 2005 I'm not totally familiar with the smaller J spec brake, but AFAIK know they don't have these pins that you knock out. I know the UK brakes do, they were a pain to remove on mine. From what I remember the pins were just over 6mm. Ah, good point. My car is a UK spec Quote Link to comment Share on other sites More sharing options...
piehound Posted December 23, 2005 Share Posted December 23, 2005 i changed all mine last week and the gits where stuck solid it took ages getting 1 out the rest where ok and they aint been painted, the tool is just a drift Quote Link to comment Share on other sites More sharing options...
supRo Posted December 23, 2005 Share Posted December 23, 2005 Jap spec caliper/pads don't have the pins, only UK spec Quote Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted December 23, 2005 Author Share Posted December 23, 2005 REALLY!! Thats great news as I'm sure I'll have paint problems. Can anyone else confirm? Quote Link to comment Share on other sites More sharing options...
supRo Posted December 24, 2005 Share Posted December 24, 2005 NA and Standard JAP spec brakes are the same AFAIK. Mines were painted too. A doddle to swap the pads and it was the first time I had changed pads on any car! Quote Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted December 24, 2005 Author Share Posted December 24, 2005 Thanks SupRo. I hope I have the same luck Quote Link to comment Share on other sites More sharing options...
carl0s Posted December 24, 2005 Share Posted December 24, 2005 Oh well at least you know what to do on a UK car Quote Link to comment Share on other sites More sharing options...
carl0s Posted December 24, 2005 Share Posted December 24, 2005 i changed all mine last week and the gits where stuck solid it took ages getting 1 out the rest where ok and they aint been painted, the tool is just a drift I feel for ya. One of mine had been mashed a bit on the end and just wouldn't fit through. Right PITA it was. Quote Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted December 24, 2005 Author Share Posted December 24, 2005 like i said, all info appreciated mate Quote Link to comment Share on other sites More sharing options...
Need4Speed Posted December 26, 2005 Share Posted December 26, 2005 A tip with UK calipers. Fit new pins and keep an old one as a removal tool. DON'T use a centre punch... you'll flare the old pin and it will have to be cut out. Quote Link to comment Share on other sites More sharing options...
michael Posted December 26, 2005 Share Posted December 26, 2005 Does anyone have the part number for the pins to hand? (Still abroad, no EPC in an internet cafe ) Quote Link to comment Share on other sites More sharing options...
merckx Posted December 26, 2005 Share Posted December 26, 2005 Does anyone have the part number for the pins to hand? (Still abroad, no EPC in an internet cafe ) 90240-06019 Quote Link to comment Share on other sites More sharing options...
michael Posted December 26, 2005 Share Posted December 26, 2005 Cheers I was planning to renew any parts that I could on the brakes so I'll add these to the list. Quote Link to comment Share on other sites More sharing options...
Gordon F Posted December 26, 2005 Share Posted December 26, 2005 90240-06019 Front and rear are different. Which ones are you after? Quote Link to comment Share on other sites More sharing options...
michael Posted December 27, 2005 Share Posted December 27, 2005 Rears to begin with as I suspect I'll have to kill one of mine to remove it but fronts would be handy to have too If anyone has the numbers for the full brake refurb kits too that would be very useful Quote Link to comment Share on other sites More sharing options...
Need4Speed Posted December 27, 2005 Share Posted December 27, 2005 That's the front pin part no. Also useful are: 47748-14080 Anti-rattle spring 90468-12021 Pin retaining clip (UK Front) Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted December 27, 2005 Share Posted December 27, 2005 This is why I cannot give a fixed price to replace UK caliper pads. Sometimes only drilling out will remove the pad retainer pins. I keep new pins and pin clips in stock, but mainly for my own usage. They can be a total PITA. jap spec calipers have few foibles with regard to pad changing in comparison. Quote Link to comment Share on other sites More sharing options...
Need4Speed Posted December 27, 2005 Share Posted December 27, 2005 That's why I always use new pins at a pad chnage and keep spares in stock. Sod's law dictates the pins will never jam if you've got new spares to hand. Quote Link to comment Share on other sites More sharing options...
Matt Harwood Posted December 27, 2005 Share Posted December 27, 2005 I always give mine a light sanding and cake them in copper grease when re-fitting. It's worked OK for me for the past 5 years, but I think it's time for some new ones next pad/disk change... Quote Link to comment Share on other sites More sharing options...
Gordon F Posted December 27, 2005 Share Posted December 27, 2005 Rears to begin with as I suspect I'll have to kill one of mine to remove it but fronts would be handy to have too If anyone has the numbers for the full brake refurb kits too that would be very useful For UK brakes only: 90240-06019 - Pin @ 89p each (in 01/03) presume rear 90240-06017 - Pin @ 90p each presume front as more expensive 04479-14140 - Repair kit front (seals, boots, bleed nipples - not pistons) £27.69 04479-14130 - Repair kit rear @ £22.31 As far as I can remember, pistons are the same front and rear and were about 16 quid each when I was doing mine I also ran a reamer (6mm I think) through the calipers before refitting the pins. Quote Link to comment Share on other sites More sharing options...
