Side window removal and replacement
bens747
The door windows are quite easy to take out. Door card off, then take off the big black metal bracing plate, then undo the three fasteners with blue surrounds that go through the glass and lift it out.
Mark the postion of the fasteners on the glass before removing them. Makes it a lot easier when reassembling - otherwise you'll have trouble getting the alignment right
