Daston Posted December 19, 2005 Share Posted December 19, 2005 Hi guys Got a quick question is it possible to get he back CAT removed with a stock exaust system inplace? Or do I need to replace the whole thing? Quote Link to comment Share on other sites More sharing options...
Nic Posted December 19, 2005 Share Posted December 19, 2005 Hi guys Got a quick question is it possible to get he back CAT removed with a stock exaust system inplace? Or do I need to replace the whole thing? Yes a decat pipe(s) can be fitted with the stock exhaust. Quote Link to comment Share on other sites More sharing options...
Daston Posted December 19, 2005 Author Share Posted December 19, 2005 sweet any idea how much they are or how long it takes labour wise? Thinking of am xmas prezzy for the old girl Quote Link to comment Share on other sites More sharing options...
Nic Posted December 19, 2005 Share Posted December 19, 2005 sweet any idea how much they are or how long it takes labour wise? Thinking of am xmas prezzy for the old girl Contact member Chris Wilson, he supplies individual pipes to replace the first and second cats, the advantage of 2 separate pipes is that come MOT time the 2nd cat can be replaced easily. Quote Link to comment Share on other sites More sharing options...
Pig Posted December 19, 2005 Share Posted December 19, 2005 whats the performance gain like de-catting an NA? Also does it affect fuel consumption much? Quote Link to comment Share on other sites More sharing options...
Rob Posted December 20, 2005 Share Posted December 20, 2005 There is a slight gain in performance, most noticable when you put the second cat back in for the MOT. Fuel consumption is, of course, an irrelevance. Quote Link to comment Share on other sites More sharing options...
Tom S Posted December 20, 2005 Share Posted December 20, 2005 There is a slight gain in performance, most noticable when you put the second cat back in for the MOT. Fuel consumption is, of course, an irrelevance. Getting my 2nd Cat taken out today and a resistor ring put in to add back pressure. £30 fitted !! Quote Link to comment Share on other sites More sharing options...
Daston Posted December 20, 2005 Author Share Posted December 20, 2005 wow is that all?? Also whats the chances of passing an Mot with just on CAT? (on 1993 car) Quote Link to comment Share on other sites More sharing options...
Daston Posted December 20, 2005 Author Share Posted December 20, 2005 wow is that all?? Also whats the chances of passing an Mot with just on CAT? (on 1993 car) Oops ment one CAT Quote Link to comment Share on other sites More sharing options...
Pete Posted December 20, 2005 Share Posted December 20, 2005 Fuel consumption is, of course, an irrelevance. Fuel economy is better on an NA after decatting. Quote Link to comment Share on other sites More sharing options...
magicmatty Posted December 20, 2005 Share Posted December 20, 2005 Oops ment one CAT My '95 NA passed fine with no cats on! Bearing in mind all NA's are imports, the number plate and chassis/eng numbers will probably not show up on the new MOT system, so they HAVE to run the test ion the default setting - meaning higher pass levels and 99.9% chance of both cats off passing OK! Hope yours goes fine, cats off is a simple job, undo bolts, replace gaskets, rebolt. Simple Quote Link to comment Share on other sites More sharing options...
