Electrical wizards, help needed!
dilocruzy
Hi there,
My foglamp (aftermarket penny sized button) has not worked for a while, so today i decided to try and sort it out.
Bulb was fine, so were all fuses, so I opened the pannel to find that only one of the three leeds to the foglamp button was connected so I though that it would just be a case of connecting the other two and problem sorted! what a mistake! i must have inverted the +- leads of the connection (I know feking idiot)... I lost both my dash lights and indicator/hazzard lights!
The dash lights were easy to sort, new fuse and working fine, but the indicator hasent worked since, tried replacing the fuses (in car and engine bay ones) but no luck. Strangely enough, when I switch on/off the alarm, all indicator lights flash as usual!
Any other ideas on what could be going wrong?
Many thanks!
Dan
Isnt it anoying when some customer service geek asks you if your computer is pluged on to the mains when you have a computer problem? well, its even more anoying to them when the computer wasent!
Mate you are a star! wish all my soop´s problems could be sorted with pluging something in!
check to see if the wiring plug to the hazard switch is still connected as that will stop the indicators and hazards from working.
