maxaerott Posted December 17, 2005 Share Posted December 17, 2005 i have bought a new tps sensor fitted it and its still the same problems as befor i have discovered that the od light and slip cont light only start to flash when the car is revved. i had the tps off the thorttle body and is didnt flash or show a code as soon as i moved the rotary sensor of the tps the od and slip light started to flash again. is it down the the wiring or could it be something much worse. Max Link to comment Share on other sites More sharing options...
maxaerott Posted December 18, 2005 Author Share Posted December 18, 2005 anyone any ideas ? Link to comment Share on other sites More sharing options...
Timwildman Posted December 18, 2005 Share Posted December 18, 2005 I think if you supply a few more details people might be able to help more. i.e. year, transmission etc... there was a big thread about vvti tps do a search and all might become clear. Link to comment Share on other sites More sharing options...
maxaerott Posted December 18, 2005 Author Share Posted December 18, 2005 will do thanks the car is a 1994 auto tt non vvti. so any more help peeps would be appreciated . Max Link to comment Share on other sites More sharing options...
Ian C Posted December 18, 2005 Share Posted December 18, 2005 Are you still logging the fault code? If so then perhaps there is a fault in the wiring between the sensor and the ECU. -Ian Link to comment Share on other sites More sharing options...
maxaerott Posted December 19, 2005 Author Share Posted December 19, 2005 Hi Ian yes there still the fault code there. i think its multimeter time. Link to comment Share on other sites More sharing options...
