New Mk4 owner - Hi to all
Guest ajm
Guest mark poulton
hello, if the rear hatch rattles put some of that sticky velcro stuff on the rubbers - you use the soft side of it and you can get it in black, try john lewis stores, it sorted mine out!!!!
cheers for that mark - will give it a try.
also found the back end to be all over the place while on the m/way - felt very unsettled and not really confident with the feel. maybe i still have to get used to the car :rolleyes: . new rear shocks were fitted with std springs, wheel tracking was done, no damage underneath either. tyres are 265/35/18 and there's more than enough tread.
has anyone else experienced this as well? your thoughts would be appreciated. thanks.
Did you have all the suspension bushes/joints checked? Sounds like could be worn suspension components to me.
thanks Nic - sounds like another trip to Thames Wheel & Tyre in Slough.
Just got me thinking - if anyone in Berkshire / surrounding areas within distance needs tracking done, I can highly recommend them without a doubt. Very good equipment, but also very busy - you need loads of patience and Ricky is the guy to ask for.
If anything is worn and you need new parts, give me a shout as I have all part numbers and can get at a big saving over Toyota UK prices.
