SupraHuman Posted December 15, 2005 Share Posted December 15, 2005 Got a Innovate Motorsports AFR gauge almost fitted.In the manual there is 2 cables called analog OUT 1&2.These two hooks up to the ECU,but which wire/s do i tap into on the ECU?? Is it HT1 Main heated oxygen sensor & HT2 sub heated oxygen sensor? Cheers CK Link to comment Share on other sites More sharing options...
eyefi Posted December 15, 2005 Share Posted December 15, 2005 are you reading the stock narrowband o2 sensor? Link to comment Share on other sites More sharing options...
SupraHuman Posted December 16, 2005 Author Share Posted December 16, 2005 are you reading the stock narrowband o2 sensor? I'm not reading anything yet m8,i got the gauge and sensor wired up to a 9V battery and hooked up to my lap-top for a free air sensor test.i did not proceed with the wireing yesterday as i was and still is unsure where to run the analog out wires.I think some of the wires runs to the OBD1 sensor and there is two different ground cables etc. Got a lot of research to do here AND i hate wireing Link to comment Share on other sites More sharing options...
eyefi Posted December 16, 2005 Share Posted December 16, 2005 dude, i'm not familiar with the item you have but it sounds like those outputs are for dataloging. if you are connecting to a wideband sensor then no connection to the ecu is needed. what does it say in the instructions? Link to comment Share on other sites More sharing options...
Soonto_HAS_soop Posted December 17, 2005 Share Posted December 17, 2005 The outputs are for either datalogging or for adding a second gauge, such as a narrowband so that it runs a wideband signal, not sure why you would want to do that mind. Link to comment Share on other sites More sharing options...
JohnA Posted December 17, 2005 Share Posted December 17, 2005 not sure why you would want to do that mind. to send the signal to the ECU instead of the stock sensor. This is useful when the wideband physically replaces the stock sensor (not the case with the supra though) Link to comment Share on other sites More sharing options...
Soonto_HAS_soop Posted December 17, 2005 Share Posted December 17, 2005 to send the signal to the ECU instead of the stock sensor. This is useful when the wideband physically replaces the stock sensor (not the case with the supra though) My "not sure why you would want to do that though" was actually regarding the possibility of adding a second gauge. Link to comment Share on other sites More sharing options...
