supradibbs Posted December 15, 2005 Share Posted December 15, 2005 the rad pipe that goes into the block and the to screw in plugs and also the one pin water temp connector and really would like the connector to have the wire still spliced in so i can just solder it into my wire loom thanks after this very urgently cash waiting Link to comment Share on other sites More sharing options...
supradibbs Posted December 16, 2005 Author Share Posted December 16, 2005 Link to comment Share on other sites More sharing options...
Dragonball Posted December 16, 2005 Share Posted December 16, 2005 Wayne - being really thiick here - but really dont know which bits you are after? Link to comment Share on other sites More sharing options...
supradibbs Posted December 16, 2005 Author Share Posted December 16, 2005 ok right pipe is the rad pipe not the one that come stright off the rad (rubber on stock) but the solid pipe after that that goes into the block has two water feeds this pipe has two connectors screwed in also need both these,one of these is a one pin connector (smaller of the two)also require the plug that goes onto this and as i said if it has the wire still attached aswell so i can splice it stright in hope this makes things a little clearer thanks chaps Link to comment Share on other sites More sharing options...
supradibbs Posted December 16, 2005 Author Share Posted December 16, 2005 please someone must have one Link to comment Share on other sites More sharing options...
