supra-alex Posted December 15, 2005 Share Posted December 15, 2005 and i want to clean my headlights what shall i do only clean the front and see how that comes up ? i can see a little condensation but only when u put lights on....ideally i would be a new set and practice refurbishing the old ones but need £££ and wrong time of year for that !!! for others who's supra is an everyday car how do get around it ? as its a bit of risk taking them apart and sumin goes wrong then ur screwed ? can you clean em without taking lens off ? Quote Link to comment Share on other sites More sharing options...
tbourner Posted December 15, 2005 Share Posted December 15, 2005 I polished the front of mine with glass polish, it helped a bit. Then luckily I had a crash and they got replaced anyway!! Quote Link to comment Share on other sites More sharing options...
supra-alex Posted December 15, 2005 Author Share Posted December 15, 2005 I polished the front of mine with glass polish, it helped a bit. Then luckily I had a crash and they got replaced anyway!! moral of the story then: leave em. 2 of my mates had written off their M3 and supra straight after they were serviced !!!! sumthing very dodgy at work in this world........ Quote Link to comment Share on other sites More sharing options...
Ian W Posted December 15, 2005 Share Posted December 15, 2005 I polished the front of mine with glass polish, it helped a bit. Then luckily I had a crash and they got replaced anyway!! bloody hell mate, bet you really had to look for that silver lining!!! lol Quote Link to comment Share on other sites More sharing options...
toyotasuprauk Posted December 15, 2005 Share Posted December 15, 2005 Yes polishing the outside does help a bit, its worth a try doesnt take long. Quote Link to comment Share on other sites More sharing options...
Alex Posted December 15, 2005 Share Posted December 15, 2005 Fit HID's then there is no problem Quote Link to comment Share on other sites More sharing options...
Pete Posted December 15, 2005 Share Posted December 15, 2005 Then luckily I had a crash and they got replaced anyway!! That's the weirdest definition of lucky I've heard in a while... Quote Link to comment Share on other sites More sharing options...
DamanC Posted December 15, 2005 Share Posted December 15, 2005 T-cut scratch remover made a noticeale difference Quote Link to comment Share on other sites More sharing options...
Mike M Posted December 15, 2005 Share Posted December 15, 2005 Sounds daft but I used autoglym metal polish and then normal T cut. Took at lot of polishing but looks much better than it was. Quote Link to comment Share on other sites More sharing options...
TrickTT Posted December 15, 2005 Share Posted December 15, 2005 I stripped, cleaned and rebuilt mine in a day. Left them in the warm overnight for the sealer to set up, then put them back on the car next morning. Its an easy job once you get over sticking them in the oven. Quote Link to comment Share on other sites More sharing options...
supra-alex Posted December 15, 2005 Author Share Posted December 15, 2005 I stripped, cleaned and rebuilt mine in a day. Left them in the warm overnight for the sealer to set up, then put them back on the car next morning. Its an easy job once you get over sticking them in the oven. was that yor first time ? any problems ? that goes for everyone do they get any problems the first time they attempt it ? Quote Link to comment Share on other sites More sharing options...
Lucifer Posted December 15, 2005 Share Posted December 15, 2005 I stripped, cleaned and rebuilt mine in a day. Left them in the warm overnight for the sealer to set up, then put them back on the car next morning. Its an easy job once you get over sticking them in the oven. Yeah what he said, but take your time. Quote Link to comment Share on other sites More sharing options...
supra-alex Posted December 15, 2005 Author Share Posted December 15, 2005 Yeah what he said, but take your time. once youve put new sealant on how long do you leave it in the oven for before it sets ? not overdoing it.... Quote Link to comment Share on other sites More sharing options...
Lucifer Posted December 15, 2005 Share Posted December 15, 2005 once youve put new sealant on how long do you leave it in the oven for before it sets ? not overdoing it.... The process which I do for alot of people is as follows:- 1. Warm you oven up to 100oC 2. Remove all the clips on the light 3. Get a BIG flat blade screw driver. 4. Place light in oven for 5 mins once preheated 5. Remove light and prise the front off. 6. Polish the inside and out with glass or meguires plasit polish and a buffer on a drill. 7. Remove ALL old seland so you have a good chanell aorund the light and is clean 8. Buy some good qiality sealant 9. Put selant all round the channel, dont be stingey here. prob need 2 tubes (small) 10. Put both bits back n oven for 1 min to soften sealent you missed(separatly) 11. Push the two bits together and replace clips ASAP. 12. Keep in warm house environment for 1/2 day then in garage 1/2 day to cure.... Your done! Quote Link to comment Share on other sites More sharing options...
supra-alex Posted December 15, 2005 Author Share Posted December 15, 2005 The process which I do for alot of people is as follows:- 1. Warm you oven up to 100oC 2. Remove all the clips on the light 3. Get a BIG flat blade screw driver. 4. Place light in oven for 5 mins once preheated 5. Remove light and prise the front off. 6. Polish the inside and out with glass or meguires plasit polish and a buffer on a drill. 7. Remove ALL old seland so you have a good chanell aorund the light and is clean 8. Buy some good qiality sealant 9. Put selant all round the channel, dont be stingey here. prob need 2 tubes (small) 10. Put both bits back n oven for 1 min to soften sealent you missed(separatly) 11. Push the two bits together and replace clips ASAP. 12. Keep in warm house environment for 1/2 day then in garage 1/2 day to cure.... Your done! thank you Quote Link to comment Share on other sites More sharing options...
Guest gzaerojon Posted December 16, 2005 Share Posted December 16, 2005 make sure you use the oven and not the grill:blush: they kinda go yellow and melt (i dont do cooking) but i know how to turn the oven on now Quote Link to comment Share on other sites More sharing options...
