Supra_Al Posted July 24, 2003 Share Posted July 24, 2003 The auto tensioner for my auxilary belt 'creaks'.Hard to explain as the engine revs from idle, there is a split second 'creak' as the engine loads the belt.With the engine off,if you push down on the belt you can make the tensioner creak.Has anyone else had this? Will i eventually have to buy another,if so how much are they? Can i remove it (if so how) and grease it up? Al. Link to comment Share on other sites More sharing options...
mos Posted July 24, 2003 Share Posted July 24, 2003 Yes i have this on my sz as well and its been like that for about a year and more. I usually spray some silicon into the spring area. Its held on by three bolts and the timing covers need to come off. Just the top and middle i believe. Whatever you do dont drop the bolts down the bottom cover if you decide to change it. Link to comment Share on other sites More sharing options...
Supra_Al Posted July 24, 2003 Author Share Posted July 24, 2003 Mos thanks,glad i'm not the only one!When you spray it,does this stop it for a while? What is it called,the stuff you use? Al. Link to comment Share on other sites More sharing options...
