race r33 gtr 650ps in japan
Jurgen-Jm-Imports
this is a pure animal allegedly.
Skyline GT-R V-Spec
1995 expression
Running 32200 kilos
One owner
The restoration calendar:.
Circuit Aida of reference time TI: It is 38 seconds of one minute.
87.5 pie JE forged piston half skirt
TRUST H section Conrod
Purity Reinforced crank Taft processing
TRUST T78-33D Turbine kit
JUN Camshaft 272/272 9.7 lifts IN/EX
N1 Lubricating oil pump
Head side laboratory
Port expansion IN/EX
Valve guide
Valve seat cutting
Valve specular processing
NISMO reinforced metal
TRUST Mass oil pan
Oil strainer processing
SARD Oil element SPORTS MAG+
NISMO Reinforced engine mount
TRUST Racing plug #8
TRUST Type R Racing blow off valve
SRD Original Oil obtaining tank
SRD Original Full titanium Straight Muffler
TRUST Full stainless steel Exhaust manifold (Include it in the turbine kit. )
TRUST Reception desk pipe (Include it in the turbine kit. )
TRUST Waist gate Type C 1.2kg/mm
TRUST Twin Saction Brake line kit
TRUST Earincs Air cleaner x 2
TRUST Three layers Intercooler
TRUST intercooler OUT pipe kit
TRUST 16 steps Oil cooler
SRD Original Three side flow type aluminum layer radiator
N1 Water pump
Birionrortempsarmo
SAMCO Radiator Silicon hose
NISMO High pressure Radiator Cap 1.3
SARD 740cc Injector
TRUST Fuel delivery Pipe 2in1
BOSCH A large capacity Fuel pump
EARLS Stainless steel Mesh Fuel Line
NISMO Adjustment type fuel regulator
OS technique laboratory Crossing mission kit
OS technique laboratory Reinforced input shaft
OS technique laboratory Triple plate clutch (Damparres)
NISMO Strengthening Mission mount
AP RACING Reception desk 6POT Brake system
370 Reception desk Brake Rotor
TRUST ALCON Rear 4POT Brake system
320 Rear Brake Rotor
RAYS TE37 18x9.5+12 White Four
Slick DUNLOP racing 260/655R18
QUANTUM T5 Another tank type car high note kit Attenuation power adjustment type
Eye Bach Up-grade Spring
Reception desk MANATEE RACING Flpiroarm Kit
Rear Cuzco Adjustment type Upper arm
Bush Making to Flpiroborl
SRD Original Rear member color
Rear Member reinforced reinforcement
Body Rivet reinforcement
Cuzco Roll gauge 11 point expression Dash penetration Each part pillar reinforcement
SRD Original Reception desk Tower bar
SRD Original Reception desk jack point production
SRD Original Pulling hook
APEXI POWER FC Full computer
(SRD Present car suiting))
R33 Type M Eafromatar x2
Defe addition meter
Boost + Water temperature + Temperature of oil + Oil pressure + Exhaust temperature + Moo
APEXI REV/SPEED Meter
Circuit Time attacker
Blitz Atasar Control System
NISMO Reception desk bumper ‰ü
SRD Original Frontodifuzar
SRD Original Carbon canard (adjustment type)
SRD Original FRP bonnet
TOP SECRET Side step
Rear Earobampar
VOLTEX Carbon GT-WING TYPE3
Five Full acrylic fiber The glass
need i say more now i wish i had some spare cash
Now that i do like! that is exactly the way i would want to own a liner (maybe without some of the "styling" on it though. hmm i wonder if i could scratch enough pennies together for it? not likely :p
its only 650hp,
LMFAO!!!
im sure if that went on some of the rolling roads in this country it would read a little more than 650hp...
Guest Flat4_ire
Race cars are functional first and showy 200th! If the front end works who cares how it looks!!! For gawds sake it's not trying to be a show car.
exactly, stop tryin to pick out silly things bout the car lads, its an animal and i doubt much would touch it on a track!!
