Name an item...
Digsy
...that you always end up with loads of becase you can't find it when you need it so you buy another one. Then you immediately find the one you were looking for originally. :D
Here's two starters:
1. Foreign mains adapters (usually bought at the airport).
2. Radiator bleed keys.
torch,,,,its allways dark when i need it, then i can never find it cos its dark, so i need a torch,its allways dark when i need it, then i can never find it cos its dark, so i need a torch,its allways dark when i need it, then i can never find it cos its dark, so i need a torch,its allways dark when i need it, then i can never find it cos its dark, so i need a torch,its allways dark when i need it, then i can never find it cos its dark, so i need a torch,its allways dark when i need it, then i can never find it cos its dark, so i need a torch,its allways dark when i need it, then i canits allways dark when i need it, then i can never find it cos its dark, so i need a torch, never find it cos its dark, so i need a torch,its allways dark whits allways dark when i need it, then i can never find it cos its dark, so i need a torch,en i need it, then i can never find it cos its dark, so i need a torch,its allways dark when i need it, then i can never find it cos its dark, so i need a torch,
tt steve
i need a torch.
Those bloody silicone sealant applicator guns! You find the silicone sealant and you go running off to where you are SURE the applicator gun thing is and it's not there! Go and buy another and Hey, you find the other! I have about 10 now. I keep one in EVERY room just in case. :whistle:
