Cam caps
Jake
How can I tell which cam cap goes where?
In Tony License's How to:- Valve Stem Seal Replacement guide it says the caps are "stamped with their number on top, along with an arrow that points towards the front of the engine" but mine aren't!
Mine have letters on them rather than numbers and some are the other way around to most of them. There's no arrows on them indicate the correct orientation. It just doesn't look right to me.
Should I just refit them in the same order they came off ?
Thanks for any help.
I'm sure they have numbers on as well (Probably the one thing I didn't get a picture of - typical!). Maybe stamped onto one of the side faces. E1, E2, E3 etc, I1 I2 I3.... I vaguely remember them being quite faint. Give them a real good clean up in some oil and see if you can make anything out.
Dammit, I'm gutted that I didn't take a picture of it. I'm quite close to gettting the spanners out... then again it is bloody cold. Sorry Jake!
In fact the more I think about it I'm pretty certain they had numbers on.
