Air temp measurement
JohnK
I don't think wind chill applies to sensors...
Wind chill is the lowering of the body’s temperature, sensors don't have this so will not be affected.
I seem to remember a demo of this once, only when they wrapped the sensor in a damp cloth did it show the wind chill.
Have a look http://observe.arc.nasa.gov/nasa/earth/wind_chill/chill_home.html, I really like the shivering man!!!
Paul.
:ok:
Well With a temp sensor in free air in front of the throttle butterfly, I am seeing temps of between 5 and 15 degrees above ambient, but after a run when the engine is off this goes upto around 60c.
The sensor has been calibrated in a static enviroment.
So whats the concensus of opinion, is it a false reading due to air speed?
Does this mean a gauge can be used to display an output from the ecu? :)
it could if the gauge was calibrated to the sensor.
i could tell you what voltage relates to what temp, you could just read it with a multimeter if you didn't want yet another gauge in the car.
If the sensor is placed *after* a water injection point, then yes, you'd have 'windchill' effect.
Otherwise you wouldn't.
With the engine off there is no airflow, so it would just show the air temp inside the throttle body --- easily 40C above ambient
nah, sounds realistic, not too sure what your charged air cooling setup is.
Thats the thing, I have a stock side mount that has seen better days, Im trying to work out if its a problem, by these results it isnt and a FIMC is a waste of money.
(waits for traders to spring to the defence of FIMC's)
do you get the same results on a hot dry day or a sustained high boost run?
I imagine my SMIC is probably in much the same state. (Some fins damaged - general abuse from 12 years of driving - no core damage) and my temps remain absolutely solid at 1.1 bar right up to the red line.
I have just put it in (for a lot less than £40) and we are a running short of hot dry days at the moment. However I was giving it some stick. As you would expect the higher the car speed the cooler the temps.
Im running a T61, EGTs rarely go north of 840.
Mine remained absolutely steady as a rock, no gain or loss. Perhaps that's a sign of my poorly IC, perhaps it should drop as I'm going quicker.
