Turbo timer
chris aka fonz
i have a turbo timer but since fitting an oil temp gauge and reading tuning books the best and really only way to cool your engine after a thrash is to cruise along sedately with air moving through the engine it is quite surprising how long the engine oil temp takes to come down, sometimes up to 20 minutes, IMHO a static car sat idling for 2 minutes on a timer is a total waste of time, if you dont believe me buy an oil temp gauge they're much more usefull
Hmmm ... I've always let my car idle before switching off. Giving the oil time to cool. I've got a Blitz and it's set to 2 minutes.
That might be overkill .. just playing safe.
Have you not been leaving idle time before switching the engine off ?
Always leave it running mate as i thought you were supposed too however if you read JohnA site http://www.max-boost.co.uk/max-boost/ it has conflicting advice about it !
Some good info on there , well worth a read .
If you're boosting hard on the motorway and turn left for the services, then YES, if you do it very quickly you risk switching off before the vital cooling-off period.
But in what other real case will you be tempted to switch off immediately right after a high-boost run? Won't you have to plod along a parking lot, residential area, etc? That would be more than 30 seconds of low-load operation, probably more than 1 minute as well.
Don't forget that the water jacket in the turbos is there for this exact reason, to stop the bearing from getting too hot. Even with the water pump stopped, the heat-absorbing capacity of the coolant is *very* high before it bubbles up and vaporises. Even then, it's main function is to stop the *oil* from carbonising around the bearing --- which a good synthetic won't do if kept below 140C.
If you've swapped for an air-cooled single then you might do with some more idling, especially if you don't change the synthetic often.
You can't get any worse than an aircooled bike engine running an aircooled turbo on high boost (non-intercooled), and if you don't need a turbo timer there, why would you need anywhere else?
not really, a turbo typically spools down to idle from full boost in a second or thereabouts.
These 10-minute 'cooling' idling periods that people go through can do more harm than good.
A guy here recently had his timer go nuts and it kept idling the car for many hours :eek:
fair enough, I do the same after hard runs, although I prefer driving off-boost, that shifts air through the rads and is better for the engine.
I know of a guy who was obsessively idling his MitsiGTO for 5-10mins after reversing it out of the garage. *That* is wrong and definately not neccessary
