keron Posted July 10, 2003 Share Posted July 10, 2003 hi, does anyone know how the fan comes off as mine has broke! there is this spring thing on the end but i dont want to be a hero and pull anything off as it may make things worse. thanks keron Quote Link to comment Share on other sites More sharing options...
Guest Martin F Posted July 10, 2003 Share Posted July 10, 2003 You need to unbolt the 4 (or 5) bolts on the pulley on the front of the water pump. Quote Link to comment Share on other sites More sharing options...
keron Posted July 10, 2003 Author Share Posted July 10, 2003 is that it??? do i have to replace anything else while putting it back (seals etc) Quote Link to comment Share on other sites More sharing options...
Guest Martin F Posted July 10, 2003 Share Posted July 10, 2003 Nope that's it. Bolt on and bolt off. Quote Link to comment Share on other sites More sharing options...
keron Posted July 10, 2003 Author Share Posted July 10, 2003 thanks martin Quote Link to comment Share on other sites More sharing options...
Steve W Posted July 10, 2003 Share Posted July 10, 2003 I think Keron's a bit SHOCKED that, for once, something's quite 'simple' on a Soop.... ! ! "the Petrol goes in fairly normally too ! !" (well, except the Optimax/Boosters/and excessive AMOUNTS ) Quote Link to comment Share on other sites More sharing options...
Steve Cargill Posted July 10, 2003 Share Posted July 10, 2003 Word of caution, the fan is in front on the pully the drive belt goes over. When you unbolt the nuts on the fan this pully is loose, just sitting on the bolts. It will stay there, just be cautions. Also, I carefully got the fan assembly in and out without the airbox (filter in my case) in place. It was fiddly, but by carefull rotation it came out OK. Quote Link to comment Share on other sites More sharing options...
keron Posted July 11, 2003 Author Share Posted July 11, 2003 all done...just need to find a fan now! does anyone know how much they cost from toyota? thanks Quote Link to comment Share on other sites More sharing options...
Guest Martin F Posted July 11, 2003 Share Posted July 11, 2003 Lots, Albundy asked recently and i think they were about £130, just for the fan!!!!! Best to scour scrapyards on that one, or go for electric fans. Quote Link to comment Share on other sites More sharing options...
