Need to borrow someones 2nd cat failed my mot
Gazzawu
rite failed emissions test. here are the results:
CO 0.01%vol passed
HC 70ppm passed
Lambda 1.22 failed (limit 1.03)
I decatted the 2nd cat and i think there is a leak in the exhaust. but will help greatly if anybody can borrow me their 2nd cat. mines is an NA but i think the 2nd cat shares the same design with the jspec tt. all expenses paid for if required.
changed plugs a couple of months ago. along with distributor cap and rotor, oil, filter, spark plug wires and both lambda sensors. i knew i was running rich before i had the lambda sensors changed and that cleared up.
results from last years mot were:
CO 0.24%vol passed
HC 127ppm passed
Lambda 1.03 passed
and that was when i was running rich. I live in the city centre and most of my journeys are short so there must be a lot of fuel sitting about in the injectors or something. need to use some redex and fuel treatment.
but what can account for the higher lambda readings?
I failed on that, all i did was clean the lamba sensor in petrol...well soak for 10mins, then let it dry out fully.
Then before MOT gave car a good hard drive to get Cat temps as high as possible and it passed fine. (not saying yours will, but it may do!)
i have a second cat you can borrow mate, just done mine, don't think mot due just yet
