Best Supra ever made was . . ?
Darren-K
  • Replies 91
You may have to wait a while there arent to many about. You also need to see a stock VVTi dyno against a stock JDM car, on the same dyno, same day etc if you are to draw any meaningful conclusions.
I have driven both, as have others and their is a difference as stated previously, but not sure you will ever agree.
Nice Ash, trouble with mods is that there are too many factors that blur the lines.. Im still waiting to see a stock dyno sheet, that would be better to compare with.
Come on then you two, sat around here all day, you should have had this organised by now, start a thread get 3 cars and we're there.....
Can I suggest we have an NA as well? The question about how a decat will affect an NA is often coming up.
NO!! TT's Only :p
Only kidding, yep a dyno of a decatted and non decatted NA would be good....just make sure they have the same gearbox :)
Guest Flat4_ire
NO!! TT's Only :p
5whp max id imagine from changing box on n/a
Forget NAs for now, Im confident that the VVti NA makes more of a difference than the standard block.
Bully for you, but seeing as we have only possibly one VVTi NA on the board I don't really give two hoots about the difference between the two, but I'm an interested in the effects of the relatively common NA mods.
