Robert Posted December 4, 2005 Share Posted December 4, 2005 well as some of my know, my friend had a supra and wasent looking after it very well....some of you might remember this thread: http://www.mkivsupra.net/vbb/showthread.php?t=51764 Anyways he came down to me this morning says the cars smoking and he has no boost at all. When he arrived i told him to drive down a private road and there was so much white smoke pouring out the back i couldn't see where he went, also i couldn't hear any turbo or BOV noises. There was so much white smoke comming out of that car it was so bad! we did a compression test and the results are: 200, cyclinder 1 190, cyclinder 2 185, cyclinder 3 190, cyclinder 4 180, cyclinder 5 187, cyclinder 6 I took a drive in the car and there was no power and it kept shaking over 2000rpm. I also took a reading from the OX1 port and it was between 0.23v-0.25v, so i take it its running lean on warm idle. The car sounds rough and is smoking badly. anyways a lesson to be learnt and that is when i say change the oil and dont rev on a cold engine then do it! also there was oil in all the pipes and i mean alot. Quote Link to comment Share on other sites More sharing options...
suprasport Posted December 4, 2005 Share Posted December 4, 2005 I also took a reading from the OX1 port and it was between 0.23v-0.25v, so i take it its running lean on warm idle. that will be beccause it cant cope with all the extra air flow from his bonnet scoop Quote Link to comment Share on other sites More sharing options...
Robert Posted December 4, 2005 Author Share Posted December 4, 2005 that will be beccause it cant cope with all the extra air flow from his bonnet scoop Quote Link to comment Share on other sites More sharing options...
Pig Posted December 4, 2005 Share Posted December 4, 2005 It was only a matter of time...poor guy but he had it coming to him! Quote Link to comment Share on other sites More sharing options...
Ian C Posted December 4, 2005 Share Posted December 4, 2005 Poor car more like, the sooner he gets a BMW and ruins that instead the better. Perfectly good block and turbos ruined -Ian Quote Link to comment Share on other sites More sharing options...
Robert Posted December 4, 2005 Author Share Posted December 4, 2005 im hoping to buy the car off him so i can fix it, i hated when he bought the car because i knew he would drive it the way he did his rover. I really am shocked at the amount of smoke i saw comming out, it was a fresh import and no service history but he never changed any fluids or belts. I dont support the way he acted towards his car its such a shame to see a supra in that state, but thought i would post up about it as it will let new members know how much damage can be done if you dont care or look after your supra. Quote Link to comment Share on other sites More sharing options...
dangerous brain Posted December 4, 2005 Share Posted December 4, 2005 Oil in the airbox is piston rings shagged isn't it? Quote Link to comment Share on other sites More sharing options...
Robert Posted December 4, 2005 Author Share Posted December 4, 2005 plenty of oil in the air box,also the spark plug in number 5 had tiny bits of metal around it Quote Link to comment Share on other sites More sharing options...
dangerous brain Posted December 4, 2005 Share Posted December 4, 2005 That'll mean no cylinder walls left either then? Not to worry you can get an engine with tubbies on for circa £1600 so in comparison to a £60 high quality oil and filter change a bargain really Quote Link to comment Share on other sites More sharing options...
Robert Posted December 4, 2005 Author Share Posted December 4, 2005 im charging him full toyota prices......... Quote Link to comment Share on other sites More sharing options...
Daston Posted December 4, 2005 Share Posted December 4, 2005 dont supose he'd swap for a looked after N/A (when it's fixed) at least the poor car will have the handy andy air box ripped off Quote Link to comment Share on other sites More sharing options...
Pete Posted December 4, 2005 Share Posted December 4, 2005 im hoping to buy the car off him so i can fix it, I thought you were pi$$ed off with repairing Supras? Quote Link to comment Share on other sites More sharing options...
Robert Posted December 4, 2005 Author Share Posted December 4, 2005 I thought you were pi$$ed off with repairing Supras? not when im making money from it Quote Link to comment Share on other sites More sharing options...
normore1 Posted December 5, 2005 Share Posted December 5, 2005 Sorry to disagree but it doesn't sound like blown rings with those compression numbers nor from the other symptoms. More likely he blew off one of the hose/pipes between the turbos and the intake manifold. Probably at the X-over pipe. This would account for the rough running, lots of smoke and the low O2 sensor readings which indicates running rich (not lean). AMHIK If he blew a piston or the rings the compression would be way low. The oil in the air box is probably either due to another problem or too much oil used on a foam or cotton mesh after market filter. derek Quote Link to comment Share on other sites More sharing options...
normore1 Posted December 5, 2005 Share Posted December 5, 2005 my apologies meant to say low O2 = lean. Air will be brought into the combustion chamber through leak in the pipes which will bypass the MAF (if UK spec ) so it will not add enough fuel to acheive good A/F ratio (stoichiometric). derek Quote Link to comment Share on other sites More sharing options...
Robert Posted December 5, 2005 Author Share Posted December 5, 2005 its a j-spec and we checked all the pipes around the back of the turbos to the IACV etc and they all looked fine. It has the stock jap spec air box and toyota panel filter fitted. I doubt the amount of smoke it was not because it was running rich, i cant stress how much smoke it was, it was pure white smoke although it had a tint of blue when he drove off. Quote Link to comment Share on other sites More sharing options...
Robert Posted December 5, 2005 Author Share Posted December 5, 2005 http://www.mkivsupra.net/vbb/showthread.php?t=35940&highlight=lambda+sensor this thread contradicts what you say about a low voltage figure meaning overfuelling. Quote Link to comment Share on other sites More sharing options...
normore1 Posted December 5, 2005 Share Posted December 5, 2005 I corrected myself in the second message where I stated that the O2 sensor reading low means lean condition. Here is what I believe happens: as the throttle opens up air is drawn into the engine but if the hose is blown off the engine sucks some of the air in after the MAF (or speed density sensor). Fuel is added based upon the MAF or SDS reading which is incorrectly low so the mixture is lean causing misfiring (some fuel does not even ignite) hence the chugging and rough running. Unused fuel from the numerous misfires may be blown out the exaust. Engine will rev with no load but will not run smoothly nor idle. I blew off the crossover pipe and this is exactly the symptoms I had including the smoke. If a set of piston rings are blown the engine will run just not very well until something seizes. IMHO there is no way you can get 170 psi+ compression with blown rings soo something else is wrong. derek Quote Link to comment Share on other sites More sharing options...
normore1 Posted December 5, 2005 Share Posted December 5, 2005 BTW, the pipes to check are the hoses/pipes (big 2.5") from the turbos to the intercooler across over and up into the intake manifold (not the IACV, or other small hoses). I'll bet one of them is blown off. Very common to blow them off at high boost and get the symptons you saw. Good luck. derek Quote Link to comment Share on other sites More sharing options...
Robert Posted December 5, 2005 Author Share Posted December 5, 2005 thanks derek i'll have a look Quote Link to comment Share on other sites More sharing options...
pab_s Posted December 5, 2005 Share Posted December 5, 2005 make sure you add chav tax to his bill. I think it is currently 75%. Quote Link to comment Share on other sites More sharing options...
Soonto_HAS_soop Posted December 5, 2005 Share Posted December 5, 2005 I corrected myself in the second message where I stated that the O2 sensor reading low means lean condition. Here is what I believe happens: as the throttle opens up air is drawn into the engine but if the hose is blown off the engine sucks some of the air in after the MAF (or speed density sensor). Fuel is added based upon the MAF or SDS reading which is incorrectly low so the mixture is lean causing misfiring (some fuel does not even ignite) hence the chugging and rough running. Unused fuel from the numerous misfires may be blown out the exaust. Engine will rev with no load but will not run smoothly nor idle. I blew off the crossover pipe and this is exactly the symptoms I had including the smoke. If a set of piston rings are blown the engine will run just not very well until something seizes. IMHO there is no way you can get 170 psi+ compression with blown rings soo something else is wrong. derek Good diagnosis, but as he has a J Spec, he doesn't have a MAF, he has a MAP sensor. Quote Link to comment Share on other sites More sharing options...
Robert Posted December 5, 2005 Author Share Posted December 5, 2005 just gone to have a look and the intercooler pipes seem fine, they are all on right. Quote Link to comment Share on other sites More sharing options...
Robert Posted December 5, 2005 Author Share Posted December 5, 2005 make sure you add chav tax to his bill. I think it is currently 75%. you must mean 175% Quote Link to comment Share on other sites More sharing options...
Ian C Posted December 5, 2005 Share Posted December 5, 2005 If it's white and blue smoke and you aren't getting any power then it's probably the turbos gone. The lack of maintenance and oil changes would gum up the oil feed in the bearing area and the bearings would overheat, grind metal, and fail. This failure would probably cause coolant (white) and oil (blue) smoke, and lots of it, because the bearing jacket has both of those plumbed in. Are you losing coolant? Does it smoke on idle? Does it smoke on revup and/or overrun? I'll buy the car off him for a grand -Ian Quote Link to comment Share on other sites More sharing options...
