Guest kennyf Posted December 3, 2005 Share Posted December 3, 2005 Tacho speedo required as mines ain't playing ball anymore? Link to comment Share on other sites More sharing options...
Whitesupraboy2 Posted December 3, 2005 Share Posted December 3, 2005 is it sat right at bottom and not moving? if so check ur conversion box earth wire!! as this killed mine Link to comment Share on other sites More sharing options...
Guest kennyf Posted December 3, 2005 Share Posted December 3, 2005 Its sits at the bottom then when I'm doing about 30 it starts to move, think I gubbed it fitting my dials!! Yes I know I am a tit! Link to comment Share on other sites More sharing options...
Guest kennyf Posted December 6, 2005 Share Posted December 6, 2005 still after one of these please , anyone? Link to comment Share on other sites More sharing options...
Jake Posted December 7, 2005 Share Posted December 7, 2005 A tacho (rev counter) or a speedo? For a Facelift or pre-facelift Supra? If it a tacho you want do you want an auto or manual one? Link to comment Share on other sites More sharing options...
Guest kennyf Posted December 7, 2005 Share Posted December 7, 2005 really beed the speedo Jake but my rev counter is playing up as well so could maybe be doing with both..... its for an auto. Link to comment Share on other sites More sharing options...
Guest kennyf Posted December 17, 2005 Share Posted December 17, 2005 Still after one of these .... Link to comment Share on other sites More sharing options...
Lucifer Posted December 17, 2005 Share Posted December 17, 2005 Just buy a road angel!! lol Link to comment Share on other sites More sharing options...
Guest kennyf Posted January 3, 2006 Share Posted January 3, 2006 Still needed for a jspec auto .... Link to comment Share on other sites More sharing options...
Nic Posted January 3, 2006 Share Posted January 3, 2006 Still needed for a jspec auto .... Kenny, if you need a price for a new one give me a shout. Link to comment Share on other sites More sharing options...
tDR Posted January 3, 2006 Share Posted January 3, 2006 Sounds like you didn't zero the needle when fitting your dials kenny - you need to lift / bend the needles over the stops and see where they naturally rest (it will be way below zero) with the engine off. Then you temporarily mark that position before removing the needles to change dials (and yes the old dials do come off) and then refit the needles in the same position with the new dials in place before then bending them back over the stops to rest on them again. ^^ That's how it should be done. To correct now it's fecked involves taking the needles off at a set speed verified by whatever GPS device you can get a hold of and placing the speedo at the right speed and the tacho is best done at idle when the car is warm - it should be at 850rpm iirc. HTH, Brian. Link to comment Share on other sites More sharing options...
Guest kennyf Posted January 3, 2006 Share Posted January 3, 2006 Sounds like you didn't zero the needle when fitting your dials kenny - you need to lift / bend the needles over the stops and see where they naturally rest (it will be way below zero) with the engine off. Then you temporarily mark that position before removing the needles to change dials (and yes the old dials do come off) and then refit the needles in the same position with the new dials in place before then bending them back over the stops to rest on them again. ^^ That's how it should be done. To correct now it's fecked involves taking the needles off at a set speed verified by whatever GPS device you can get a hold of and placing the speedo at the right speed and the tacho is best done at idle when the car is warm - it should be at 850rpm iirc. HTH, Brian. I thought that by winding it round so much trying to get it work that I'd killed it so the GPS setup could be all it needs? Link to comment Share on other sites More sharing options...
tDR Posted January 3, 2006 Share Posted January 3, 2006 Yep Link to comment Share on other sites More sharing options...
