Simon Posted July 7, 2003 Share Posted July 7, 2003 I believe that there are normally two silver boxes behind the stereo system lying on top of the transmission tunnel. I am led to believe that one of these is the active spoiler ecu (please give me one as I'm missing it) but does anyone know what the second silver box is for please. Thanks Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 7, 2003 Share Posted July 7, 2003 ABS? There's also a plastic electric aerial control box i think. Link to comment Share on other sites More sharing options...
Simon Posted July 7, 2003 Author Share Posted July 7, 2003 Chris, the plastic boxes sit on top of the radio, and one of them is an antenna relay?. But there are two metal ECUs that sit behind the radio/cd unit on the transmission tunnel, one of them is the active spoiler ecu. I don't know what the other is as there are no lables on it. Link to comment Share on other sites More sharing options...
Thorin Posted July 7, 2003 Share Posted July 7, 2003 Does the autobox have a separate ECU? Link to comment Share on other sites More sharing options...
Matt Harwood Posted July 8, 2003 Share Posted July 8, 2003 The autobox ECU is beside the engine ECU under the passenger kickwell. The metal ECU's behind the radio, on the transmission tunnel are ABS and active spoiler... And I've got a little black box next to them The ones on the radio, are air-con, (cream coloured box), and aerial relay, (smaller brown box). HTH Link to comment Share on other sites More sharing options...
Simon Posted July 8, 2003 Author Share Posted July 8, 2003 Thanks again Matt. Link to comment Share on other sites More sharing options...
efc Posted July 8, 2003 Share Posted July 8, 2003 The ones on the radio, are air-con, (cream coloured box), and aerial relay, (smaller brown box). > If anyone knows where I can get one of those cream coloured air con ecu boxes for a 96 NA SZ-R I would be eternally grateful. Have no air conditioning and suffering badly! Link to comment Share on other sites More sharing options...
Thorin Posted July 8, 2003 Share Posted July 8, 2003 Traction control next to the engine ECU too isn't it? What about Cruise control, I think that has a small ECU too. Think that one's behind the dash somewhere. Link to comment Share on other sites More sharing options...
Matt Harwood Posted July 8, 2003 Share Posted July 8, 2003 I stand to be corrected, but I don't think traction control has a seperate ecu, I believe it's done by the engines ecu... Electronic Throttle Control System? The cruise control ecu is up under the dash, just to the left of the steering. Link to comment Share on other sites More sharing options...
Thorin Posted July 8, 2003 Share Posted July 8, 2003 Quote Originally posted by Matt Harwood I stand to be corrected, but I don't think traction control has a seperate ecu, I believe it's done by the engines ecu... Electronic Throttle Control System? The cruise control ecu is up under the dash, just to the left of the steering. I only mentioned it because while looking through the EPC I saw there was "Computer, Traction Control" (89631-9601) Link to comment Share on other sites More sharing options...
GavinL Posted July 8, 2003 Share Posted July 8, 2003 Quote Originally posted by Matt Harwood I stand to be corrected, but I don't think traction control has a seperate ecu, I believe it's done by the engines ecu... Electronic Throttle Control System? The cruise control ecu is up under the dash, just to the left of the steering. UK spec car has a TRAC ecu, long gone in my case Link to comment Share on other sites More sharing options...
Matt Harwood Posted July 9, 2003 Share Posted July 9, 2003 Quote Originally posted by Thorin I only mentioned it because while looking through the EPC I saw there was "Computer, Traction Control" (89631-9601) There could well be, I just don't recall seeing one. There is another ecu next to the engines ecu on a manual car and I'm not sure what that is... Link to comment Share on other sites More sharing options...
Guest Martin F Posted July 9, 2003 Share Posted July 9, 2003 Trac ECU is next to the main engine ECU in the passengers footwell. AFAIK all the autobox functions are integrated into the main engine ECU on the MKIV. Link to comment Share on other sites More sharing options...
Matt Harwood Posted July 9, 2003 Share Posted July 9, 2003 I've just had a look at the ecu's in the kickwell of the manual. There are two. a large one which is the main engine ecu and a small one, (about 1/2 the size), with "Throttle Control - MT" written on it... I guess that's self explanatory. On the auto, the other ecu is almost the same size as the engines ecu. I'll have a look what it has written on that later... I know it has "AT" at least. Just another couple of ecu locations while we're at it... The SRS system is under the armrest of the centre console and there's a little fuel controller in the N/S rear quater.... Link to comment Share on other sites More sharing options...
Simon Posted July 9, 2003 Author Share Posted July 9, 2003 Quote Originally posted by Matt Harwood ... The SRS system is under the armrest of the centre console Well I'll be dammed, I didn't know they had Seatbelt Restraint Systems fitted. Link to comment Share on other sites More sharing options...
Matt Harwood Posted July 10, 2003 Share Posted July 10, 2003 Only if you've got airbags. I'm not sure Toyota use that exact terminology, I just used it 'cause I was too lazy to type "airbag ECU". I thought SRS stood for 'Safety Restraint System' Link to comment Share on other sites More sharing options...
Guest Martin F Posted July 10, 2003 Share Posted July 10, 2003 Supplemental Restraint System............thought i'd seen it somewhere. http://www.mkiv.com/specifications/product_Information_book_93/model_line-up/sep20_13.jpg Link to comment Share on other sites More sharing options...
Simon Posted July 10, 2003 Author Share Posted July 10, 2003 In other words ..... Airbag. I suppose SRS looks better embossed on the dash than Airbag. Probably gives the car another 10Hp. Link to comment Share on other sites More sharing options...
