johnd-mkiv Posted December 1, 2005 Share Posted December 1, 2005 The top part of my rad near the neck had a long crack in it, some c@*t has bodged it with body filler. I have done a temp repair on it, but really need a new one! whats my best bet? uprated rad or an oem rad? who and where can I get one and what sort of price will I be looking at for one? cheers john d Link to comment Share on other sites More sharing options...
JohnA Posted December 1, 2005 Share Posted December 1, 2005 Perhaps you could contact Steve Manley, as mentioned in other threads of CJ. (Toyota dealer doing good prices for members here) It would be interesting to know what sort of price he can do for the rad --- might go for one myself in the future Link to comment Share on other sites More sharing options...
hadyn Posted December 1, 2005 Share Posted December 1, 2005 Are you losing coolant then? Koyo make good rads if you can find one. Link to comment Share on other sites More sharing options...
Nic Posted December 1, 2005 Share Posted December 1, 2005 If you want a good price for a Power Enterprise Double Row Radiator or OEM Toyota radiator, drop me an email, see link in my sig. Link to comment Share on other sites More sharing options...
heckler Posted December 1, 2005 Share Posted December 1, 2005 The top part of my rad near the neck had a long crack in it, some c@*t has bodged it with body filler. I have done a temp repair on it, but really need a new one! john d Join the club dude Link to comment Share on other sites More sharing options...
Ray Posted December 1, 2005 Share Posted December 1, 2005 Perhaps you could contact Steve Manley, as mentioned in other threads of CJ. (Toyota dealer doing good prices for members here) It would be interesting to know what sort of price he can do for the rad --- might go for one myself in the future IIRC correctly Steve does them for around £220 ish inclusive. Link to comment Share on other sites More sharing options...
JohnA Posted December 1, 2005 Share Posted December 1, 2005 220ish would be good enough for me. Stock rad, quality! (bar the fecken plastic end-tanks) Link to comment Share on other sites More sharing options...
heckler Posted December 1, 2005 Share Posted December 1, 2005 not bad concidering i was quoted £350 inc vat from Mr T. Link to comment Share on other sites More sharing options...
Nic Posted December 2, 2005 Share Posted December 2, 2005 not bad concidering i was quoted £350 inc vat from Mr T. Yes I'm fairly sure the £222 price is too good to be true, if it is the right price that is a good deal. Link to comment Share on other sites More sharing options...
tDR Posted December 4, 2005 Share Posted December 4, 2005 Yep, I found that a Koyo aluminium rad (about 3 times thicker than the OEM one and with proper welded on metal end tanks) with 2x SPAL fans was only slightly more expensive than a new OEM rad from Toyota! Much better off uprating the rad if you already run more power or plan to run more. Brian. Link to comment Share on other sites More sharing options...
johnd-mkiv Posted December 4, 2005 Author Share Posted December 4, 2005 should have a secondhand one sorted for now, thanks for your help Link to comment Share on other sites More sharing options...
heckler Posted December 4, 2005 Share Posted December 4, 2005 Yep, I found that a Koyo aluminium rad (about 3 times thicker than the OEM one and with proper welded on metal end tanks) with 2x SPAL fans was only slightly more expensive than a new OEM rad from Toyota! Much better off uprating the rad if you already run more power or plan to run more. Brian. Where did you get the Koyo rad from? Link to comment Share on other sites More sharing options...
tDR Posted December 4, 2005 Share Posted December 4, 2005 Dusty @ MVP Link to comment Share on other sites More sharing options...
TLicense Posted December 4, 2005 Share Posted December 4, 2005 There's two ways you can buy a radiator from toyota. (Certainly was for my GT-Four) A brand new one, or a re-conditioned one. The price difference was shocking. Needless to say the recon one should be pretty much every bit as good as a new one. Link to comment Share on other sites More sharing options...
colsoop Posted December 4, 2005 Share Posted December 4, 2005 You can get all the bits to refurb your radiator from Mr T, see attached pic Link to comment Share on other sites More sharing options...
hadyn Posted October 21, 2007 Share Posted October 21, 2007 You can get all the bits to refurb your radiator from Mr T, see attached pic Bumping this thread today How much is the top bit (part 16441 in the pic) from Toyota and what is involved in fitting it? Is it easy to swap the top bit of the radiator? Link to comment Share on other sites More sharing options...
markrzs Posted October 21, 2007 Share Posted October 21, 2007 Bumping this thread today How much is the top bit (part 16441 in the pic) from Toyota and what is involved in fitting it? Is it easy to swap the top bit of the radiator? I'd be very interested in this too as my rad has bust in the same place Link to comment Share on other sites More sharing options...
johnd-mkiv Posted October 21, 2007 Author Share Posted October 21, 2007 I have a rad forsale as I now run a koyo in my car Link to comment Share on other sites More sharing options...
Shovels Posted October 21, 2007 Share Posted October 21, 2007 john, how hard was the koyo to fit? Link to comment Share on other sites More sharing options...
johnd-mkiv Posted October 21, 2007 Author Share Posted October 21, 2007 john, how hard was the koyo to fit? easy job mate around an hours work Link to comment Share on other sites More sharing options...
Shovels Posted October 26, 2007 Share Posted October 26, 2007 I meant to also ask how much and where from? Link to comment Share on other sites More sharing options...
Chris Wilson Posted October 26, 2007 Share Posted October 26, 2007 I can do OE type rads at a great price for cash. e-mail me for prices if interested. Correct core thickness (NOT an N/A rad) with or without auto cooler (which works great as a PAS cooler on a manual car if you buy the auto rad....) repairing an old rad is a mugs game, IMO. I may have a very low age / mileage auto UK rad coming in soon, it's having an aftermarket one fitted, against my advice Link to comment Share on other sites More sharing options...
hadyn Posted October 26, 2007 Share Posted October 26, 2007 how much for the UK rad and does it differ in any way to a jap spec rad? Link to comment Share on other sites More sharing options...
