Fitting RLTC
Soop Dogg
Just got my RLTC and was wandering if anyone has got any advice on fitting it.  Wiring diagrams would be a great help re the ABS unit and generally any help would be greatly appreciated.  E-mail me directly if you happen to have any pic's/diagrams etc.
Thanks in anticipation!:)
Guest Martin F
Brian you need to look here :-
http://www.mkiv.com/manual/index.html
For the wiring diagrams.
The ABS unit is a pig to do as it is under the stereo and the wires are extremely short.
Best tip i can give you is to make sure you remove the passenger seat before even starting :)
The last job is to load up a decent file of settings and dump what's in there.
Speak to Phil Wall about an appropriate file.
Good Luck
