Supra's not working - help for a non-techie please???
FaithStalker
Originally posted by John Packham
Matt - when you say "cured itself" do you mean a self-fixing piece of electronics, or a dodgy contact?:D
:innocent: Cheeky bugger! My car aint got no dodgy contacts! :p
It's powered by the ignition, so it automaticly gets reset every time the ignition is switched off/on...
Well guys,
I went home and didnt get a chance to take it above the limiter, (traffic), but i found the little blighter behind the dash, seemed ok, just pushed in a few connections made sure all was tight,
moved the little box as well so it was jammed into a corner instead of rattling around inside the dash!!!!!!!!
took a look at the ECU in the passenger footwell, the black box holding it together was a bit lose as the bolts were not tight, and a pink wire that run up to the limiter thing had been stripped and just making taped over, which had slipped off leaving exposed wire. I taped it all up again
took it for a little run
grin factor returned :)
A few thankyou's -
to everyone who read/posted to the thread to appease my panic stricken mind!!!!!!!
Leon who was willing to take in my car to check it out with almost ZERO notice !!!!!
JIC for willing to replace it and refit another one F.O.C even though i bought it off them 2 years ago !
