FaithStalker Posted July 4, 2003 Share Posted July 4, 2003 After a lovelly Cambridge meet last night (Thu) there was nothing wrong with the Supra, gave it a bit of welly against ChrisR's GT4 all the way round to 140 leptons on our private test track... different matter this morning, i was really late for the train, so had to give it a bit of welly when it was cold, I got up to 121 leptons (overdrive was on, manu off) and the engine died, it dropped back a few 1000 revs and then picked up again......then died again!!!!! all boost was lost. I backed off, and accelerated hard , boost was up to stock levels (its a stock car) of 0.7 all the way round to 121 leptons, then death again no warning lights no flashing nothing as i am not a techie the only thing i can think of is its lost 4th Gear??????? could it be the box was very cold???? didnt like being worked hard ? i ran out of time and out of ...track... and had to park it and come to work, i'll test the 4th gear theory tonight using the MANU and OD buttons to engage and keep 3rd until PAST 121 (to see if its speed related) then try and engage 4th. crap crap crap any ideas? anything i can check??? (with my 0 knowledge of Supras) - any help will be much appreciated! theres no noises, no clangs, nothing, its just like you've let off the throttle..... anyone got Leons number? *SOB* anyone got a good Loan rate recently? Quote Link to comment Share on other sites More sharing options...
jjgage Posted July 4, 2003 Share Posted July 4, 2003 No idea what tghe problem could be - i'll leave that up to the techies! But here's Leon's no. Leon - JPS Motorsport - 01908367100 Jonny Quote Link to comment Share on other sites More sharing options...
Steve Cargill Posted July 4, 2003 Share Posted July 4, 2003 I think the gearbox gets from it's "I'm cold and haven't woken up yet" mode in a few seconds, so that should not have been an issue. When you hit 120, what revs were you doing, was it about 7k and didn't change up. You can test 4th at normal speeds, when cruesing just press the OD button and it should change down into 3rd and the revs go up accordingly. Could it be a speed limiter problem, it's about the right sort of speed for that to happen. Quote Link to comment Share on other sites More sharing options...
FaithStalker Posted July 4, 2003 Author Share Posted July 4, 2003 booked in at Leons now for this week, revs are 4300 when it cuts, boost is at maximum when the cut comes in wierd wierd wierd Quote Link to comment Share on other sites More sharing options...
ChrisR Posted July 4, 2003 Share Posted July 4, 2003 Mate, this sounds like the limiter. When i got my Supra it was supposed to have been delimited however after 3 months of ownership i finally hit the 120 mark and experienced exactly what you have described. I took it back to the importer and they confrimed they forgot to fit the limiter. Once fitted problem solved. Now i know your car is alraedy de-limited as you have not had high speed problems before, however this sounds like the limiter is failing and has returned the car to its stock settings. I guess you could check the wiring. Quote Link to comment Share on other sites More sharing options...
FaithStalker Posted July 4, 2003 Author Share Posted July 4, 2003 Cool, any ideas where this wiring would be??? I'll try and search on delimiter and see if i can get any diagrams, pictures of where to look! As its going to Leon's tomorrow i'll have to try and figure it out tonight - would it look fairly obvious??? Quote Link to comment Share on other sites More sharing options...
Ian C Posted July 4, 2003 Share Posted July 4, 2003 Did it go alright in the lower gears, full boost all the way up to 5000+rpm? Or did you only really give it some in 4th? -Ian Quote Link to comment Share on other sites More sharing options...
richardharmon Posted July 4, 2003 Share Posted July 4, 2003 Sorry to hear about the technical trouble. I hope it’s a faulty de-limiter, certainly sounds like the speed limiter the way it backs off like that, and no warning lights is a good sign! Does 4th gear work okay at slower speeds? Quote Link to comment Share on other sites More sharing options...
ChrisR Posted July 4, 2003 Share Posted July 4, 2003 Originally posted by FaithStalker Cool, any ideas where this wiring would be??? I'll try and search on delimiter and see if i can get any diagrams, pictures of where to look! As its going to Leon's tomorrow i'll have to try and figure it out tonight - would it look fairly obvious??? Find out from JIC where there stick the box of tricks and trace the wires back. The thing is it could be faulty within the box. Im going to stick my neck out here and say im 100% certain its the delimiter. Hope im right as thats a cheap fix. Quote Link to comment Share on other sites More sharing options...
ChrisR Posted July 4, 2003 Share Posted July 4, 2003 Originally posted by richardharmon What the hell do you think you are doing posting on here, this is for members only...... Quote Link to comment Share on other sites More sharing options...
FaithStalker Posted July 4, 2003 Author Share Posted July 4, 2003 Well after reading quite a few articles in the "SEARCH" about this it certainly sounds like a delimiter problem.... and this sparked a little memory i had of last nights "run" with ChrisR, as i came off the private track and went home on normal roads around a few islands, i heard a rattle and something rolling around coming from the passenger side of the car....... could this be something to do with the ECU/delimiter ?!?!?! could something have come off....... i usually put my steering lock down in the passenger footwell, i wonder if its hit something or somethings come lose! hmmmm i'm feeling a little less panicy now about the whole thing, as it does sound like its being limited - and in that case its not such an expensive fix Quote Link to comment Share on other sites More sharing options...
FaithStalker Posted July 4, 2003 Author Share Posted July 4, 2003 i cant seem to find any diagrams or pictures of the ECU / delimieter does any have any? if a wire or a clip or something has come off i could do with knowing where to put it back..... or do perhaps some peterboroughians know how its supposed to look or have some other Supra to compare it too???? :D Quote Link to comment Share on other sites More sharing options...
richardharmon Posted July 4, 2003 Share Posted July 4, 2003 Pete Betts has some very good diagrams of what needs to be done. They are specific to his de-limiter but should give you an idea of what's going on behind there! If you need to get a new one then I think his is very good, I use one of them and have had no problems with it, gearbox, spoiler and power steering all fine. http://www.trlperformance.com/dsc_mkiv.html Quote Link to comment Share on other sites More sharing options...
Digsy Posted July 4, 2003 Share Posted July 4, 2003 Tony, If you take your dash off you will find your "delimiter" behind the IP. Mine had its power and negative leads screwed to terminals on the IP circuit board, and then "crimp" bullet type connectors for the speed signal. The box itself was not supported or fixed down in any way - it was just rattling around behind the IP on its wires. It should be pretty easy to spot which wires they cut to convert the speed signal so maybe you can put the wiring back to diagnose this yourself? Incidentally, the JIC "delimiter" isn't really a delimiter. They just feed the ECU with the same 5/8 signal that the speedo and odo gets. Quote Link to comment Share on other sites More sharing options...
FaithStalker Posted July 4, 2003 Author Share Posted July 4, 2003 Cheers Darren!!!!!!! if it involves dash work etc i may take it to Leon anyway,as i'm not too hot on how things go back together, and i'm sure he'd do a much better job than me and now i know where to point him for the problem it should be relativley quick ! (he's also servicing it anyway) and may secretley without telling the MISSES decat it !!!!!!!! (cat 1 only) mwuuhahahahaaaaaaaaaaaaaaaaaaa if i manage to spot the problem and its in the passanger footwell i'll try and sort it out myself - but i pretty much know what i'm like, so i guess you'll be seeing a thread "i accidently sawed through the ECU and the passenger wing while trying to fix the delimiter" thread tomorrow morning :D Quote Link to comment Share on other sites More sharing options...
Digsy Posted July 4, 2003 Share Posted July 4, 2003 You mean you're the only Supra owner never to take his dash out? I thought you were rattle-hunter! Its really easy. Five screws for the dash, unclip all the panels. You cannot put the plugs back in the wrong sockets. Then its just four screws to get the IP forward on its loom. Go on. Do it. Doooooo iiiiiiiiiiit!! Quote Link to comment Share on other sites More sharing options...
FaithStalker Posted July 4, 2003 Author Share Posted July 4, 2003 IP?? i suppose i can give it a try, i guess if something was wrong with the wires i'd see some wires going nowhere from a black box which i'd assume would be the delimter i thought you also had to remove the stuff around the gear selector?!?!?? or is that for the WHOLE dash?!?! Quote Link to comment Share on other sites More sharing options...
Digsy Posted July 4, 2003 Share Posted July 4, 2003 Yep, you have to remove the whole dash, but it all clips together once you have the five screws out along the underside of the top part. IP = Instrument Panel - the assembly of the three dials. It is held in with four screws. Once you tilt it forward you can remove the three colour coded plugs that go into it and remove that. If your installation is like mine (it should be, we bought our cars from JIC at about the same time) you should be able to see exactly which wires were cut to fit the delimiter. Quote Link to comment Share on other sites More sharing options...
Matt Harwood Posted July 4, 2003 Share Posted July 4, 2003 Before you get too panicy, (?), you may find it will have cured itself already. My speed delimiter has occasions when it doesn't de-limit and has exacly the same symptoms as yours. If I turn off the ignition and then re-start, it's all back to normal again. Mines done it about 3 times in 20 months... I'm sure there was a thread about this sometime back and I know I'm not alone with the intermittant speed delimiter... Chances are, welcome to the club Quote Link to comment Share on other sites More sharing options...
FaithStalker Posted July 4, 2003 Author Share Posted July 4, 2003 *Another* club :-) I'll see tonight, although i defintley heard something rolling / rattling around in the passanger footwell - i think somethings come off, out, apart, whatever ! Thanks for all the advice guys - i'll be trying to put it into practice tonight... good weekend tony Quote Link to comment Share on other sites More sharing options...
Barry Posted July 4, 2003 Share Posted July 4, 2003 Originally posted by Matt Harwood Before you get too panicy, (?), you may find it will have cured itself already. My speed delimiter has occasions when it doesn't de-limit and has exacly the same symptoms as yours. If I turn off the ignition and then re-start, it's all back to normal again. Mine too, and that was on the way back from yours once Matt.! Went to overtake a car, squeezed the throttle, passed 100.....110.....115....Buuuuuurrrrrrrrrrrrr....115....110......115.....Buuurrrrrrrrrrrr. I though I'd broken something.! Pulled over, turned off engine, fired it up again and it was fine.! Quote Link to comment Share on other sites More sharing options...
Adam W Posted July 4, 2003 Share Posted July 4, 2003 Not sure on the details but I think yo have to avoid switching the ignition on with the dash panels apart, otherwise the airbag light comes on and is a bugger to turn off. Quote Link to comment Share on other sites More sharing options...
Matt Harwood Posted July 4, 2003 Share Posted July 4, 2003 That is correct Adam, but I'm fairly confident that his trip home would have been alright and he won't need to strip his dash. Just one of those freak electronic temporary f*ck-ups. Probably happen more often but the speed isn't reached to cause a problem. Quote Link to comment Share on other sites More sharing options...
Need4Speed Posted July 5, 2003 Share Posted July 5, 2003 Matt - when you say "cured itself" do you mean a self-fixing piece of electronics, or a dodgy contact? Quote Link to comment Share on other sites More sharing options...
Need4Speed Posted July 5, 2003 Share Posted July 5, 2003 FaithStalker - it's as easy to sort as refilling the rear screenwasher bottle... where-ever that is:D Quote Link to comment Share on other sites More sharing options...
