Jake Posted November 28, 2005 Share Posted November 28, 2005 I'm not having any luck finding another VVTi lump for my car but I've seen a low mileage non-VVTi 2JZ-GTE engine and turbos for sale. Apart from swapping the VVTi head, turbos , injectors, throttle body and loom onto the replacement engine is there anything else I would need to do? Do both engines use the same spec head gasket? How thick is a stock head gasket? 1.0mm? I'm going to get the VVTi head checked and skimmed if necessary but I'll need a thicker head gasket then. Please let me know if there's a reason not to do it this way - before I waste a load more of my redundancy money on yet another engine Thanks Quote Link to comment Share on other sites More sharing options...
Pete Posted November 28, 2005 Share Posted November 28, 2005 So yours is proper dead then Wouldn't importing one from Japan be an option? Maybe Nic could help out with this? They come up quite often on http://auctions.yahoo.co.jp/ Quote Link to comment Share on other sites More sharing options...
Pete Posted November 28, 2005 Share Posted November 28, 2005 See http://www.mkivsupra.net/vbb/showthread.php?t=30344&highlight=supra+japanese for a few tips Quote Link to comment Share on other sites More sharing options...
Pete Posted November 28, 2005 Share Posted November 28, 2005 vvti エンジン means vvti engine if that helps Quote Link to comment Share on other sites More sharing options...
Jake Posted November 28, 2005 Author Share Posted November 28, 2005 Cheers Pete, but if swapping the head achieves the same thing I think I'd rather do that than mess about with importing from Japan. Quote Link to comment Share on other sites More sharing options...
Alex Posted November 29, 2005 Share Posted November 29, 2005 The blocks are the same AFAIK...but 90% of what bolts to it is different... So get your head checked....then go from there... Think the stock HG is 1.2mm ... but if you have to skim .4mm then you can use the HKS 1.6mm HG.... Quote Link to comment Share on other sites More sharing options...
Ian C Posted November 29, 2005 Share Posted November 29, 2005 That's one big mofo skim Not sure at what point the head is junk because the cam journals will be misaligned too much... -Ian Quote Link to comment Share on other sites More sharing options...
garethr Posted November 29, 2005 Share Posted November 29, 2005 Not important if you're not interested in the Japanese option, but http://www.f1kits.com/Keyword%20Search.htm has a lot of Japanese language keywords for Yahoo. Quote Link to comment Share on other sites More sharing options...
Jake Posted November 29, 2005 Author Share Posted November 29, 2005 The blocks are the same AFAIK...but 90% of what bolts to it is different... So get your head checked....then go from there... 90%? I realise the intake side and exhaust side will need swapping over but what else? I think the anciliary items are the same (water pump, altenator, etc) but what about the sump and other things I may not have considered? Unfortunately I have to make a decision today whether I'm going to buy this other (non-VVTi) engine or not. Thanks Quote Link to comment Share on other sites More sharing options...
Pete Posted November 29, 2005 Share Posted November 29, 2005 Unfortunately I have to make a decision today whether I'm going to buy this other (non-VVTi) engine or not. You mean in about 7h 16m ? Quote Link to comment Share on other sites More sharing options...
Alex Posted November 29, 2005 Share Posted November 29, 2005 I'd get the block you're looking at...most of the different stuff as you've mentioned bolts to the head...and if you're using the VVTI head I can't see you having a problem - you'll then have a spare head you can get miching/fettled for the bronze one A plan or what! Cough - okmaybenot90% - cough There COULD be differences in the sump but I would have thought they wouldn't be in the way it bolts to the block - more like it's shape (if there is any difference) Quote Link to comment Share on other sites More sharing options...
Alex Posted November 29, 2005 Share Posted November 29, 2005 You mean in about 7h 16m ? Once Jake's made his decision I'd like to know where you've seen this engine....but I don't want it made public now so others can snipe. Quote Link to comment Share on other sites More sharing options...
Jake Posted November 29, 2005 Author Share Posted November 29, 2005 Thanks guys. It looks this might work then. I was hoping Terry might reply to this thread, Mig tells me Terry knows all about this vvti conversion business. Quote Link to comment Share on other sites More sharing options...
Alex Posted November 29, 2005 Share Posted November 29, 2005 He does - phone him if you get no joy on here. Quote Link to comment Share on other sites More sharing options...
Pete Posted November 29, 2005 Share Posted November 29, 2005 Didn't ChrisW have a block on its own?..and PaulE was talking about uprated blocks at ok prices? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 29, 2005 Share Posted November 29, 2005 Sump is different on VVTi, quite how it differs except in outward appearance i don't know. I have good none VVti TT block, and a mint, superb, fabulous ultra low mileage N/A engine too. No VVTi ones at the moment. Quote Link to comment Share on other sites More sharing options...
Jake Posted November 29, 2005 Author Share Posted November 29, 2005 Well I didn't get the other one It was on eBay, as Pete was hinting at. The bidding was up to £691 with 1 minute to go. So left it till the last few seconds then bid £812 but the page took a few seconds to refresh and then said "Auction Has Ended" So it went for £691 in the end, 46k miles, complete with auto box, turbos etc etc Quote Link to comment Share on other sites More sharing options...
Pete Posted November 29, 2005 Share Posted November 29, 2005 Well I didn't get the other one It was on eBay, as Pete was hinting at. The bidding was up to £691 with 1 minute to go. So left it till the last few seconds then bid £812 but the page took a few seconds to refresh and then said "Auction Has Ended" So it went for £691 in the end, 46k miles, complete with auto box, turbos etc etc That would've been cheap to drop into that NA that went for 3250 the other day! 4k (plus a bit) for a TT. Quote Link to comment Share on other sites More sharing options...
Guest Terry S Posted November 30, 2005 Share Posted November 30, 2005 Thanks guys. It looks this might work then. I was hoping Terry might reply to this thread, Mig tells me Terry knows all about this vvti conversion business. Sorry mate thought Mig asked you to PM me. Feel free. Quote Link to comment Share on other sites More sharing options...
