SteveR Posted November 27, 2005 Share Posted November 27, 2005 Would some of you more knowledgable peeps be kind enough inform the likes of me - Supra owners who know little about the deep technical stuf but want to look after our cars as much as is possible - what sort of gauges are sensible to keep an eye on everything and check it's all a-ok. OK Boost gauge is an easy one for us TT drivers, but what about things like; gearbox oil temp, engine oil pressure, engine oil temp, Air/Fuel ratio?, Exhaust gas temps, erm... anything else that can be monitored? Are these things a sensible idea or only really needed after an extent of modding - if so, what mod demands what above aspect to me monitored? How easy is it to go about adding such sensors & gauges? Is gearbox oil something that only needs monitoring if you're doing track stuff/hard driving for extended periods? Many thanks in advance oh wise people!! Quote Link to comment Share on other sites More sharing options...
CJ Posted November 27, 2005 Share Posted November 27, 2005 Fuel pressure Quote Link to comment Share on other sites More sharing options...
SteveR Posted November 27, 2005 Author Share Posted November 27, 2005 oh yeah never thought of that. Is that a 'even at stock its a good idea' one CJ? Quote Link to comment Share on other sites More sharing options...
CJ Posted November 27, 2005 Share Posted November 27, 2005 Sorry...pressed the button before fully completing. I have the following in my car: Boost, EGT, Fuel pressure, Oil pressure, AFR. The only other one I thought of fitting was the oil temp gauge. Quote Link to comment Share on other sites More sharing options...
CJ Posted November 27, 2005 Share Posted November 27, 2005 oh yeah never thought of that. Is that a 'even at stock its a good idea' one CJ? Well, its a gauge that could save your engine. If you loose fuel pressure you are in the hot brown sticky stuff. Quote Link to comment Share on other sites More sharing options...
SteveR Posted November 27, 2005 Author Share Posted November 27, 2005 I have the following in my car: Boost, EGT, Fuel pressure, Oil pressure, AFR. The only other one I thought of fitting was the oil temp gauge. Have you got a pic of your dash you can share, it must be pretty crowded??! Got to admit tho, I want as many gauges as there are things that really should be monitored. There is the added advantage of them looking cool too - the more cockpit-like my supra can be the better Quote Link to comment Share on other sites More sharing options...
Ian C Posted November 27, 2005 Share Posted November 27, 2005 I'd go in this order: Boost pressure AFRs EGTs Fuel pressure Oil temp Oil pressure -Ian Quote Link to comment Share on other sites More sharing options...
CJ Posted November 27, 2005 Share Posted November 27, 2005 This is the dash. As you can see, i have used both the air vents for the boost and EGT an dhave a pillar mount for the oil and fuel presure. The AFR gauge has since been fitted in place of the clock. The pic also shows 3 other gauges - volts, water temp and something else i cannot remember but these are definitely more for show than function. Quote Link to comment Share on other sites More sharing options...
SteveR Posted November 29, 2005 Author Share Posted November 29, 2005 That's pretty sweet CJ - I like that a lot. Quote Link to comment Share on other sites More sharing options...
SteveR Posted November 29, 2005 Author Share Posted November 29, 2005 I'd go in this order: Boost pressure AFRs EGTs Fuel pressure Oil temp Oil pressure -Ian And not bother with gearbox/oil temp? Excellent priority list - thanks Ian Quote Link to comment Share on other sites More sharing options...
Class One Posted November 29, 2005 Share Posted November 29, 2005 This is the dash. As you can see, i have used both the air vents for the boost and EGT an dhave a pillar mount for the oil and fuel presure. The AFR gauge has since been fitted in place of the clock. The pic also shows 3 other gauges - volts, water temp and something else i cannot remember but these are definitely more for show than function. Lol like you have time to monitor them in your car!!!! Quote Link to comment Share on other sites More sharing options...
Prof. Monkey Posted November 29, 2005 Share Posted November 29, 2005 CJ. I have noticed you have some auto gauges, which ones? I have an electric oil pressure guage and it doesnt work correctly! Cheers Quote Link to comment Share on other sites More sharing options...
CJ Posted November 29, 2005 Share Posted November 29, 2005 CJ. I have noticed you have some auto gauges, which ones? I have an electric oil pressure guage and it doesnt work correctly! Cheers I dont have them anymore as I fitted a touch screen in their place so cannot tell you what they were. Sorry! Quote Link to comment Share on other sites More sharing options...
CJ Posted November 29, 2005 Share Posted November 29, 2005 Lol like you have time to monitor them in your car!!!! LOL...very true...but they look cool! Quote Link to comment Share on other sites More sharing options...
Pig Posted November 29, 2005 Share Posted November 29, 2005 bit of a thread hijak, am thinking about air fuel ratio and fuel pressure. What the recommended ones? My boost and EGT gauge is one of these:http://www.spa-uk.co.uk/design/dualgauges.asp Are these god for AFR + FR? Edit: i was thinking about the DG 215 Whats best for AFR? Quote Link to comment Share on other sites More sharing options...
CJ Posted November 29, 2005 Share Posted November 29, 2005 Most people tend to go for the AEM or Innovative make of AFR gauge. I dont know anything about the ones you listed. Quote Link to comment Share on other sites More sharing options...
MARTIN R Posted November 29, 2005 Share Posted November 29, 2005 I want some for my NA, dont want to hijack the thread but anyone know where I can get a good deal on some, not bothered what make. Quote Link to comment Share on other sites More sharing options...
