Robert Posted November 25, 2005 Share Posted November 25, 2005 just wondering if the jap spec and uk spec supras both use the same boot rubbers? on my uk spec i tried to fit the boot rubbers, part number 67293-14051. When i fitted them today the boot wouldnt shut. Am i being stupid here or is there a difference? Quote Link to comment Share on other sites More sharing options...
Jake Posted November 25, 2005 Share Posted November 25, 2005 Did you take the old ones off first? They must be the same though, surely? Quote Link to comment Share on other sites More sharing options...
Robert Posted November 25, 2005 Author Share Posted November 25, 2005 hahaha jake, yes i did my new mini blow torch took care of that. Went to close the boot and the plastic parts on the boot lid bang off the boot rubbers? Quote Link to comment Share on other sites More sharing options...
Homer Posted November 25, 2005 Share Posted November 25, 2005 You'll probably need to adjust the catch on the slam panel. Quote Link to comment Share on other sites More sharing options...
Jake Posted November 26, 2005 Share Posted November 26, 2005 You'll probably need to adjust the catch on the slam panel.Is that right? I didn't know it was adjustable. Learn something new everyday. Quote Link to comment Share on other sites More sharing options...
Robert Posted November 26, 2005 Author Share Posted November 26, 2005 You'll probably need to adjust the catch on the slam panel. not sure because there is a gap all around when its down except where the plastic hits the new rubbers. Quote Link to comment Share on other sites More sharing options...
Ark Posted November 26, 2005 Share Posted November 26, 2005 You didn't put them on upside down did you? Oh, and check for the 'other' fix, which is sticking washers under the plastic bits on the tailgate - using both this fix and new rubbers would make for a very tight fit. Quote Link to comment Share on other sites More sharing options...
Robert Posted November 26, 2005 Author Share Posted November 26, 2005 ok im serious now the new boot rubbers i have wont fit properly, i have attached a picture of what they should fit like i think but when i go to close the boot it wont shut and no amount of adjusting will fix it. im sure the UK specs my have different part numbers Quote Link to comment Share on other sites More sharing options...
HunterJ Posted November 26, 2005 Share Posted November 26, 2005 Silly question, but did you replace both top and bottom rubbers? Jamie Quote Link to comment Share on other sites More sharing options...
Steve Posted November 26, 2005 Share Posted November 26, 2005 Top one is not a rubber Quote Link to comment Share on other sites More sharing options...
Robert Posted November 26, 2005 Author Share Posted November 26, 2005 no just replaced the bottom rubbers as the parts on the boot lid are plastic Quote Link to comment Share on other sites More sharing options...
HunterJ Posted November 26, 2005 Share Posted November 26, 2005 Only reason I asked was I replaced both top and bottom - and they were both very different from the originals... Quote Link to comment Share on other sites More sharing options...
Robert Posted November 26, 2005 Author Share Posted November 26, 2005 Only reason I asked was I replaced both top and bottom - and they were both very different from the originals... didnt realise that the top plastic parts could be replaced with anything but toyota parts. Quote Link to comment Share on other sites More sharing options...
HunterJ Posted November 26, 2005 Share Posted November 26, 2005 Both were bought directly from Toyota... Quote Link to comment Share on other sites More sharing options...
milocoon Posted November 26, 2005 Share Posted November 26, 2005 I did my J-spec TT today, I cut all the old rubber off the Chassis Rubbers which were well cracked and used a heat source to loosen the blue jap loctite and with a T wrench from a socket driver set got 3 screws out first time and the fourth needed more heat. My boot is harder to shut now but it does shut and I`ve still got a rattle, its quieter but on rough roads a bit annoying. I also propped up the hatch and removed the tailgate struts from the tailgate (2 x 10mm Headed bolts), there was silicon applied to all 4 pivots and some wear was evident so I resiliconed the pivots with new silicone but I`ve still got a rattle. I`ll try and adjust the boot catch next but your picture showing the chassis rubber appears to be exactly the same as my J-Spec for position. I also tried WD40 on the boot seal rubber in case that was the noise source. Price from Toyota World Patchway, Bristol for 2 CUSHION/DOOR T 67293-14051 was £2.77 each and 4 x SCREW T90159-50116 was £0.61 each. Including VAT a Grand Total of £9.38 and I ordered Wednesday and they arrived Friday. A trader on this forum quoted me £10 for just the 2 CUSHION/DOOR T 67293-14051 so members be careful as prices vary. Has anybody changed the Tailgate Struts ends and cured the rattle ? Quote Link to comment Share on other sites More sharing options...
Pig Posted November 26, 2005 Share Posted November 26, 2005 I changed both top and bottom. boot is much harder to shut. P.s they are the same as in ur pic robert Quote Link to comment Share on other sites More sharing options...
peter richards Posted November 26, 2005 Share Posted November 26, 2005 you seemed to have covered it all , i was going to sugest the struts as the last items that could be making a noise , does your tailgate stay up on its own Quote Link to comment Share on other sites More sharing options...
milocoon Posted November 27, 2005 Share Posted November 27, 2005 Hi Pete, yes the tailgate stays up fine by itself, its a little bit of an effort to raise it fully, probally not helped me squirting silicone in the pivot points. On smooth roads very little in the way of rattles but on potholed or concrete roads the rattles return. I`ll try the boot latch today, it looks like 4 plastic plugs have to come out of the boot trim to get access to screws securing the trim which covers the latch. Quote Link to comment Share on other sites More sharing options...
milocoon Posted November 29, 2005 Share Posted November 29, 2005 Weii I removed the plastic trim in the boot well to get access to this but this only offers a very small amount of adjustment as one hole in the bracket is round and the other is oval so as to allow a little bit of sideways and less up and down. I checked in the hatch and the two mounts are round so no adjustment at all on the top piece. When the boot is shut you can`t feel any play in the latch so it could be my worn pivots on the hatch dampers. I`ll have a go at the subframe bolts next as well in case they`re loose. Quote Link to comment Share on other sites More sharing options...
hadyn Posted November 29, 2005 Share Posted November 29, 2005 Did mine by sticking on two thick halfords number plate sticky pads onto the shot rubbers, voila no more rattles Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 29, 2005 Share Posted November 29, 2005 New rubbers often make for a hard to shut tail gate, try giving it a real slam, once they settle they seem to compress a bit, and all's OK. There is no adjustment provided by Toyota. Quote Link to comment Share on other sites More sharing options...
Robert Posted November 29, 2005 Author Share Posted November 29, 2005 yeah i gave it a good slam and now letting them settling in place. Quote Link to comment Share on other sites More sharing options...
JonW Posted November 30, 2005 Share Posted November 30, 2005 Did mine by sticking on two thick halfords number plate sticky pads onto the shot rubbers, voila no more rattles I did the same and it has never rattled since. Quote Link to comment Share on other sites More sharing options...
chilli Posted November 30, 2005 Share Posted November 30, 2005 when I did mine it was just as CW says, no adjustment needed or possible. The tailgate was hard to shut but after a while it settles in and now it's a good tight fit with no rattles. for 2 * 2.77 or whatever they were from Mr T it's a satisfying fix for the £ Quote Link to comment Share on other sites More sharing options...
hadyn Posted November 30, 2005 Share Posted November 30, 2005 I did the same and it has never rattled since. Lol, bootlid is a little 'stickier' to open tho! Quote Link to comment Share on other sites More sharing options...
