Guest JSpecSimon Posted November 25, 2005 Share Posted November 25, 2005 1) 1 of my sidelights has gone out which bulb do I get to replace it (J spec lights). lazy i know! 2)The back seems to be very rattly is this common or has something broke, gone etc! 3) There is also a rattle from underneath the car but only rattles sometimes, could this be the heatsheild? or could the sideskirts rattle now and then? Thanks Simon Quote Link to comment Share on other sites More sharing options...
Ian W Posted November 25, 2005 Share Posted November 25, 2005 dunno what bulb it would be mate, am sure someone will be along to tell you which soon enough.... the rattle will more than likely be the hatch rubbers which you can get from Toyota quite cheap i think. do a search for it on here, that will keep you occupied for a while!! the intermittent rattle does sound like it would be a heat-shield if it's a metallic rattling sound. just get it checked out on a ramp, mate. welcome by the way, have relatives down in Dunston not too far from the Metro Centre. Quote Link to comment Share on other sites More sharing options...
supRo Posted November 25, 2005 Share Posted November 25, 2005 Sidelight will be the lowest bulb holder - quite difficult access. It twists open and the bulb holder is quite long. The bulb is a '501' 5 watt bulb. It might be easier to get the headlights out a little - quite easy, 2/3 bolts Quote Link to comment Share on other sites More sharing options...
