Cheap AFR gauge
Pete
I know it looks pants, but at 35 quid it seems cheap enough.
Anyone tried one / heard of "auto gauge"
http://cgi.ebay.co.uk/WHITE-AIR-FUEL-RATIO-LED-GAUGE-WITH-F-KIT-NOT-BOOST_W0QQitemZ8015019548QQcategoryZ72215QQrdZ1QQcmdZViewItem
I'd have thought for something electronic the quality would be required in the sensor more than the gauge itself, so you could always upgrade the sensor?
Thoughts?
Guest Terry S
I had a similar thing about 6 years ago. Lumention I think. Little better that useless TBH
Just checked they dont seem to sell it anymore, just a much lager digital one
Only a wide band sensor is any use at all, TBH. I'll show you the Motec one in the Skyline, it's pretty good. You can't put a wide band probe on a narrow band readout, they need totally different conrol circuitry. There are some reasonable priced ones that work well, nowagsays, I only bought the 9expensive) Motec unit beause it interfaces with all my other Motec stuff, and is accurate enough for reference lab usage, which sounded cool ;)
I've used such AFR gauges in the past and they did their job nicely, as long as they are seen as what they are: oil pressure lights, compared to oil pressure gauges that the widebands resemble.
Now that widebands have dropped in price so much, it's a bit silly not to consider one IMO.
You can't setup the car with a narrowband, just monitor for trouble.
Save the £35 and get a wideband, I have one of these in mine, as I cut into the dash panel to fit it and my wideband now supersedes(SP) it. It is useless for anything, as it dives off the lean scale at anything below 11.0.
Pointless, although if I was being anal, I could link my narrowband to one of the outputs of the innovate motorsports gauge and it will work as a secondary monitor....
