Gazboy Posted November 22, 2005 Share Posted November 22, 2005 Just reading archived magazine tests on a yankee Supra website, with a quick test on a HKS Supra running GT25/30 ball bearing turbos sequentialy. Didn't know you could do that! More info required! Link to comment Share on other sites More sharing options...
carl0s Posted November 22, 2005 Share Posted November 22, 2005 they're probably wrong. AFAIK the HKS big twins run in parallel Link to comment Share on other sites More sharing options...
Guest Flat4_ire Posted November 22, 2005 Share Posted November 22, 2005 Just reading archived magazine tests on a yankee Supra website, with a quick test on a HKS Supra running GT25/30 ball bearing turbos sequentialy. Didn't know you could do that! More info required!ehh arent all the twin turbo supras sequentially setup?>! Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 22, 2005 Share Posted November 22, 2005 No, all aftermarket (bigger, not just hybrid) turbos ran in parallel mode. Have yet to see any bigger as in bigger exhaust housing turbos running sequentially on a MKIV. it's possible, not quite rocket science, but would be fiendishly expensive and tricky to set up to be just right. Link to comment Share on other sites More sharing options...
Gazboy Posted November 22, 2005 Author Share Posted November 22, 2005 last paragraph, second column: http://mkiv.com/publications/other/street_power/spring_99/power03.jpg Link to comment Share on other sites More sharing options...
slick Posted November 22, 2005 Share Posted November 22, 2005 Didn't HKS do a prototype 'big twin sequential' setup at one point, but never put it into production or is that an urban myth? Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 22, 2005 Share Posted November 22, 2005 Interesting article, i for sure have never seen this "kit", not heard o anyone running one currently. I would think the stock manifold would pose an immediate problem as the runner cross section is so small, fine for high gas speeds to small (stock) turbos, but an immediate restriction when going bigger or the turbine side. Link to comment Share on other sites More sharing options...
Gazboy Posted November 22, 2005 Author Share Posted November 22, 2005 Interesting article, i for sure have never seen this "kit", not heard o anyone running one currently. I would think the stock manifold would pose an immediate problem as the runner cross section is so small, fine for high gas speeds to small (stock) turbos, but an immediate restriction when going bigger or the turbine side. Didn't TDi build one a few years ago? Link to comment Share on other sites More sharing options...
Branners Posted November 23, 2005 Share Posted November 23, 2005 so the rumour goes... JB Link to comment Share on other sites More sharing options...
Gazboy Posted November 23, 2005 Author Share Posted November 23, 2005 Is it massively difficult/expensive/impossible to fabricate a new manifold? Link to comment Share on other sites More sharing options...
Alex Posted November 23, 2005 Share Posted November 23, 2005 Is it massively difficult/expensive/impossible to fabricate a new manifold? Not hard, it's labour intensive, and going to cost you....then you have to make the system work sequentially...which isn't straight forward. Basically it's far to complicated to want to do aftermarket. Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 23, 2005 Share Posted November 23, 2005 In cast iron, yes, especially for a one off, in tube, done properly so it has a good chance of NOT cracking, also expensive, but more practical and flexible for a one off design. Link to comment Share on other sites More sharing options...
