3 uprated stock mount IC's in stock
Chris Wilson
1st come, first served, probably no more for some time due to other commitments. My all alloy stock mount intercooler, see info below. The last batch sold straight away, so first with paymenst buy them. (Four have come, one is pre sold).
Is your intercooler falling apart, the fins corroded off the tubes?
If so, its efficiency will be extremely degraded. Running more boost
than stock? Is this a good idea? NO! It's not even a good idea running
STOCK boost with an I/C like that, and when the weather struggles above
freezing it will be a VERY BAD idea! Don't want to spend over 1400
quid on a new quality front mount intercooler, only to have half of
it masked by the aperture in the front stock bumper being too small to
allow air through all the core? Even with a new aftermarket bumper that
probably fits where it touches, (from what I have seen of most Jap
products), the air will just take the easy route AROUND the expensive
FMIC, rather than through it, because no ducting provision is made. The
answer is my uprated, all aluminium stock mount intercooler. It uses all
original mountings, and the original factory sealed ducting. It uses a
state of the art core with fine pitched finning, on modern tubes with
internal turbulators. The core uses 10% more tubes than the stock unit,
too. The quality of its construction is superb, and all are fully leak
tested under pressure before despatch. Pressure drop, both internally
through the core, and aerodynamically, are less than the stock cores,
making for a very efficient unit.
Detailed pics of the intercooler can be e-mailed to serious parties.
The MKIV Supras forum have plenty of people who have bought these to get idependent opnions from.
They will sell for 620 pounds, there is no VAT to pay.
Postage and packing to UK mainland addresses is 12.50, the package is
bulky due to their fragile nature.
It's not really a fair assessment of an I/C to rate it in "power". One would assume a new single will be running in its efficiency band, not over speeding like stock ones at 1.2 bar, and I would assume you will be running about 1.2 to 1.5 bar boost max, aiming for about 500 BHP? If so these I/C's will handle it with ease.
I've fitted one of these and can recommend it to anyone who's got an original in tatty condition. Very steady boost and no more spikes.:clap:
