Auxillary drive belt tensioner
Lazarus
Following on from WSB2's unfortunate pulley "explosion", I've noticed in the last couple of days that my Auxillary drive belt tensioner has started to screech a bit, probably about to seize. (Its definately the pulley, not the belt)
Does anyody know if the bearing in the pulley can be relubricated? (ie. not a sealed unit)
Or, failing that, any of you guy's with an EPC give me a part number for a new one please?
by way i have the failed bit and i will try to take a pic.
It is now clear the arm didnt infact break.....it was the actual 3/4 thick stud on the bit that mounts to the block....good to know isnt it :faint: it snapped off right on base of the stud that the arm goes on
When i enquired about the bit it was around £94 if i remember correctly and it is the whole thing (block mounting + arm) not sure if you can buy the pulley on end of the arm seperatly...id hope you can.
  • 2 weeks later...
  • 5 years later...
  • 3 months later...
