bmw m3 evo replica (318is coupe) 80k miles mreg
GazzaGSi
Advertised on behalf of a friend:
here for sale is my 318 is coupe 1994 m reg 80,000 miles dark met blue.
spec:
140bhp m44 engine 1.8 16v
18" aez split rim style alloys with bmw centres and new 225/40/18 tyres
gmax shocks and springs 40/40 drop only covered 300 miles
powerflex bushes throughout fitted 1000 miles ago
m3 evo style staggered tip backbox, decat pipe
m3 front bumper with fogs black m3 mesh air ducts and gt splitter
m3 skirts
m3 door mouldings
m3 rear bumper and diffuser
m3 rear lights
m3 gt spoiler with built in brake light
m3 heated and electric mirrors
projector/angel eye headlights and indicators (one piece)
full black vadar interior including doorcards,centre console/arm rest
leather parcel shelf
full black carpet set
m3 clocks with silver dials
full closure rcl alarm
air con
abs
power steering
recently serviced, maintained regarless of cost, no rust at all, prime example, very very reluctant sale but weather forces it to go due to area i live in and rwd is not an option.
£5000ono CONTACT JAMIE ON 07841698575 OR PM/EMAIL [email protected] location derbyshire nr alton towers
also include for an EXTRA 1000 is:
The ultimate ground shaking window breaking install, (ultimate bass) seriously not for the faint hearted!
2x VIBE VP4 1200 WATTS DIGITAL MONOBLOCK AMPLIFIERS (2400 watts peak)
Power Output
· @ 4 ohms 1 x 450 Watts RMS (900 Watts Max.)
· @ 2 ohms 1 x 750 Watts RMS (1500 Watts Max.)
· @ 1 ohms 1 x 1200 Watts RMS (2400 Watts Max.)
· Low heat generation
· Low current consumption
· 18db/Oct. variable Low Pass Filter bult-in
· Selectable Phase shift (0 - 180) built-in
· RCA Low Level Input Jacks
· RCA Low Level Output Jacks
· Input Level Controls
· Phase Control
· Remote Gain Controller Jack
· Sub Sonic filter
· THD
· Dimensions W270 - H50 - D320
2x VIBE FLAT1 Bass Specific RCA OCC Cable
this is the best way to get the true ultimate performance from your amplifier. OCC Cable the true uncolored sound
2x Vibe BC10 amplifier bass level control
This will enable you to adjust the level of your amplifier from your dash
4x 12” vibe BlackAir version 2 subs
speaker size 12” (323cm)
rms power 500w
peak power 1500w
sensitivity 98db
frequency response 20-1500hz
impedance 4ohm
mounting depth 170mm
mounting diametre 285mm
recommended volume 1cu ft
2x twin black leather custom boxes with fibreglass front panel, Perspex windows on the end of each box, boxes painted white fleck inside with blue neons to provide the ultimate glow and look with the back seats down. False floor with big Perspex window cut out to see the amps positioned on 45 degree angle on custom built rack! Blue and silver silicon twist speaker cable lit up by neons!
This is an ultimate compotition winning system reaching 151db at usc 2005! Draws in the crowds at every show/cruise, easy instalment, ear defening bass, looks the absolute dogs dangalies and shocks people to see 4x 12” subs sitting in the back of an e36 with room left over and sounding like they do!
Genuine reason for sale, should be selling the coupe and buying a vert so theres not enough room!
Cost over £2500 to build and install with parts coming to £1800 let alone, then there was the actual design and build which was all undertaken by car electronics.
