daveyboy Posted June 19, 2003 Share Posted June 19, 2003 can anybody help me, ive bort a blitz turbo timer and its got no fitting instuctions or wiring diagrams. i have looked all nite to find some on the net but with no luck. found them for greedy and hks but not blitz .and i really want to get it fitted as ive now got new turbos fitted . thanks daveyboy Link to comment Share on other sites More sharing options...
Andrew Posted June 19, 2003 Share Posted June 19, 2003 Did you order the harness with it? Makes life alot easier if you have. Link to comment Share on other sites More sharing options...
Andrew Posted June 19, 2003 Share Posted June 19, 2003 I followed the photos on the HKS installation, as it's exactly the same. Once you open up the shelf under the steering column it will all become clearer. It then just plugs into the ignition harness replacing the old one. Is it the dual turbo timer with electronic boost gauge? If so the only tricky part is running the vaccum pipe through the firewall and into the engine. Takes about 20mins or so. Link to comment Share on other sites More sharing options...
Need4Speed Posted June 19, 2003 Share Posted June 19, 2003 I can e-mail you the wiring diagram in English if it helps. Link to comment Share on other sites More sharing options...
daveyboy Posted June 19, 2003 Author Share Posted June 19, 2003 thanks andrew, i dont no if its with the harness. ive bort it secondhand from paul and i havnt seen it yet coz its in the post. so if i havnt got a harness do you no if the colours for the the wiring is the same? so it was really easy to fit was it. where did you mount it? daveyboy Link to comment Share on other sites More sharing options...
daveyboy Posted June 19, 2003 Author Share Posted June 19, 2003 thanks john your a your a turbo life saver and it would be most appreciated . thanks again daveyboy Link to comment Share on other sites More sharing options...
Need4Speed Posted June 19, 2003 Share Posted June 19, 2003 where do I send it to? Link to comment Share on other sites More sharing options...
400BHP Posted June 19, 2003 Share Posted June 19, 2003 Daveyboy.... Disconnect your battery earth terminal and leave it for 90 seconds before touching any wiring under the column, otherwise you may possibly deploy the airbag(s). Link to comment Share on other sites More sharing options...
daveyboy Posted June 19, 2003 Author Share Posted June 19, 2003 have a hard job coz it aint got airbags but thanks for the concern . john my email is [email protected] thanks you have all been very helpfull daveyboy:D Link to comment Share on other sites More sharing options...
Andrew Posted June 19, 2003 Share Posted June 19, 2003 Easier than I first thought yes. I have no idea about the wiring without the harness I'm afraid mate, I can tell you the harness costs about £16. I mounted it on top of the steering column under the REV counter, the wire tucks away under the column nicely. I have ordered a Blitz Power SJ meter from Justin and will hopefully get that next week, so I will more than likely have all the wires out again and I'll try get some pictures for you if you haven't already done it by then. The HKS ones on MKIV.COM will help though. Link to comment Share on other sites More sharing options...
daveyboy Posted June 19, 2003 Author Share Posted June 19, 2003 okie dokie mate ta very much daverboy:D Link to comment Share on other sites More sharing options...
Sandy-m2 Posted March 15, 2007 Share Posted March 15, 2007 Just Got a Gready timer, has anyone got the install guide for that? Thanks S Link to comment Share on other sites More sharing options...
Nic Posted March 15, 2007 Share Posted March 15, 2007 Just Got a Gready timer, has anyone got the install guide for that? Thanks S Available here http://www.greddy.com/tech/ Link to comment Share on other sites More sharing options...
Sandy-m2 Posted March 15, 2007 Share Posted March 15, 2007 Thanks mate Link to comment Share on other sites More sharing options...
