turbo timer fitting instructions
daveyboy
can anybody help me, ive bort a blitz turbo timer and its got no fitting instuctions or wiring diagrams. i have looked all nite to find some on the net but with no luck. found them for greedy and hks but not blitz .and i really want to get it fitted as ive now got new turbos fitted . thanks daveyboy :)
I followed the photos on the HKS installation, as it's exactly the same. Once you open up the shelf under the steering column it will all become clearer. It then just plugs into the ignition harness replacing the old one.
Is it the dual turbo timer with electronic boost gauge? If so the only tricky part is running the vaccum pipe through the firewall and into the engine. Takes about 20mins or so.
:) thanks andrew, i dont no if its with the harness. ive bort it secondhand from paul and i havnt seen it yet coz its in the post. so if i havnt got a harness do you no if the colours for the the wiring is the same? so it was really easy to fit was it. where did you mount it? daveyboy
Easier than I first thought yes.
I have no idea about the wiring without the harness I'm afraid mate, I can tell you the harness costs about £16.
I mounted it on top of the steering column under the REV counter, the wire tucks away under the column nicely.
I have ordered a Blitz Power SJ meter from Justin and will hopefully get that next week, so I will more than likely have all the wires out again and I'll try get some pictures for you if you haven't already done it by then. The HKS ones on MKIV.COM will help though.
  • 3 years later...
