RWHP for standard MKIV ???
Peter10654
So with 25% transmission loss that'd be..... :whistle: :stickpoke
25% you think !! OK
If anybody knows more...... PLEASE !!
Anyone got a tin opener for my can of worms?? :p
Dug (Classone) put his stock J-Spec on the rollers at a meet and got 320.
320 RWHP Or Flywheel ???
Thx a lot
Peter
To work out RWHP on a rear wheel drive I was told to take off 12% - another 10bhp. This would make a jap supra 236 and a uk supra 271 at the wheels. Not sure if thats right. Dont forget that jap supras have about 314 lbft torque which is slightly more than the uk supra.
Mine standard come out 323 flywheel @ engine advantages in Witham, Essex.
looking forward to at least 380 on the 4th :D
which is how much RWHP .................?
or shall i say somewhere between 300 - 350 depending on transmission loses !?!?!?:scare:
Mines a standard J-spec with CATs and everything and it read out 337.1bhp at the flywheel. Its an auto.
It didn't read anything at the flywheel. The flywheel figure was guessed at by making a calculation base upon the power measured at the wheels or hubs and an arbitrary percentage for drivetrain loss.
Huh? You don't get the flywheel figure and work out the rwhp from that, it's the other way around.
You say yours made 323 Flywheel but what did it really make, at the wheels?
Ok, well it was 337.1bhp. Whatever that means
not got a clue Jake, can't remember seeing it on the print out.
I had this done when i first got the car a few years back when i had problems with the turbos.
I'll try and dig out the print off and post it up.
I understand that the dyno measures the RWHP and then supposedly works out transmission loses to calculate the flywheel figure i was just attempting to be funny but obviously not one of my strong points.:tomato:
This is always a contentious issue lol. As far is it counts does any figure other than the one you are putting on the actual road count for anything? A performance gain at the wheels by reducing transmission losses will result in the same effect power wise at the wheels as a performance gain by the same amount of improvement at the engine. The only power you can use is the power you put on the road you can't use heat losses in the transmission for anything other than global warming :)
id be very carful about engine advantages mine come out with a very impressive 421 bhp only running 1bar,standard turbos,fully decated, fuel cut
and blitz boost controller :haha:
when looking at the graphs it was only 313bhp at the wheels im not saying they are liers just a little genorous maybe to keep customers happy;)
