Detonation gauge
GavinL
Taken from the 200 plus mailing list, anyone heard of these?
Any good do we think?!
They look like a sequential shift but measure detonation. It`s got 1 red LED 2 yellows and 2 greens all housed in a small brushed chrome bezzel (about 5cm long by 1cm tall). It has a 12V pos and neg hook up and bolts directly to the block via any vacant bolt hole (loads on a
T16) They have been proven to be nearly as acurate as a guy with a
stethascope sitting in your passenger seat (side by side tested)
Cost  is about £160 inc vat.
This sounds like exactly what I've been after, except I was imagining something plugging directly into the stock knock sensors.  I've spoken to a couple of the more electronically minded bods off-list, and it seems that the electronics involved would be too costly for a one-off, so I'm interested in this self-contained package.
Any more details on it?  Manufacturer?  Vendor?  Magazine reviews?  Anyone actually got one?
-Ian
Quote: from Ian C on 9:56 pm on Jan. 26, 2002[br]This sounds like exactly what I've been after, except I was imagining something plugging directly into the stock knock sensors.  I've spoken to a couple of the more electronically minded bods off-list, and it seems that the electronics involved would be too costly for a one-off, so I'm interested in this self-contained package.
-Ian
I have asked for more info on this one. It appears that they are made by an individual not a mainstream company, I should be able to get a piccy shortly.
regards
It's paraphrased from one, the actual line is
"We'll be waiting, summer pagan,
for a time when no-one's cheating"
(hey, who said songs have to make sense!!)
Free small black vacuum pipe from my old engine to anyone who can name that tune...
-Ian
(Edited by Ian C at 11:15 pm on Jan. 27, 2002)
Hi....
I have received this from 200 plus group's Jason:
I`ve seen one in the flesh and they do work.
The only test that I know was worthwhile was an experianced engine tuner sat in the passenger seat with a stethascope listening for knock. He was blind folded so he couldn`t see the LCD display. Each time he heard det he called out.
EVERY time he called out the LCD display was registering the det too. I know that they use a Bosch knock sensors.
Feel free to send me a list of your questions.
Any questions send them too me ([email protected])and I will pass them on.
regards.......
have you a link to this product?
Knock sensors can be classified in two broad categories: direct
and remote measurements. They detect shock waves, a characteristic frequency in the engine, which are typically in the 5 kHz–7 kHz range.
Direct Measurements
Pressure sensors measure the pressure inside the combustion chamber of a running engine.
Currently (that I know of), Toyota is the only manufacturer
that installs pressure sensors in production engines.
Remote Measurements
Remote measurement sensors use vibrations transmitted through the structure of the engine to detect knock in the combustion chamber.
Two types of remote sensor are being used today: tuned (sepecific to that engine) and broadband (generic across engines).
So....
What method of signal conditioning and detection does this unit employ?
Does it work for wideband remote sensors (the worst of the lot), is it a tuned analogue filter or digital filter?
Does it use digital spectral analysis to determine knock?
Is the detector limited over a certain RPM range. (The higher the RPM the more noise in the engine thus the lower the signal-to-noise ratio and thus the harder it is to detect properly?
.......a few to be getting on with :-)   .......
Pete
I'm going to get one - I think it will be useful as an early warning device, and I'm under no impression that it's accurate enough for any tuning purposes.  If you want a look at it once I've got it you can.  I'll be evaluating it for the benefits of the BBS as well :)
-Ian
  • 10 months later...
Guest Terry S
Guys I'd have to say that Jason is a great guy & a great source of cheap bits inc. Samco hoses. I spoke to Jason about these earlier in the year, but wanted to see some proven results. He may have them now. Ian, see how you get on & if possible let Pete look it over. It could be the mutts nuts. Also if you get a chance, bolt Alex into the passengers seat with a stethoscope & test it.
Originally posted by TRL Performance
Remote Measurements
I know that the remote sensing type can be very hard to set up because the way that shocks are transmitted to the sensor depends upon the cylinder block structure, so the idea of putting one on "any vacant hole" sounds a bit dubious.
A straight display taken off the stock det sensor sounds like the best idea to me.
I gave it to Alex to take to Pete. Pete looked over it. That's why it's never been installed. 'nuff said, I think. The instructions were frankly rubbish as well, no wiring diagram which is a bit of a hurdle when you have four anonymour wires to plumb in. And how do you test the install? Make the engine knock? No thanks.
So if anyone actually wants one to look at or to test or whatever, they can have my never-installed one. Cost me £160, sob, you can have it for a fraction of that because I'm never going to use it. Make me a ridiculous offer and it's yours.
Just to clarify - Jason didn't make them, he just sold them. No disrespect aimed at him (I got a mega cool sticker off him just recently so I still do business with him - don't worry Terry, it's not stuck on the outside of the car)
-Ian
Jason has also supplied loads of stuff for me previously. He has some character to him ;)
Bolt Alex into the passenger seat - lmao! Is Alex available for local hardware shops or is it a special order item? ;)
Gaz.
Guest Terry S
Sorry to hear that Ian. I was really hoping it would work.
Darren's idea of taking a display off the stock knock sensor sound like an excellent idea. Pete??
Well, such is life. You can't win 'em all, and if I save other people from parting with cash on what just ain't worth it, then some good has come from the experience!
For my next trick, I will bolt Alex into the passenger seat with a stethescope - rather than a spanner... I think I've figured out why you took so long to put your car together, Terry :D
-Ian
Guest Martin F
Can't the Techtom unit already display this ?
