Thor FCD, high boost & fuel supply
carl0s
Now that the air is cold, I'm easily hitting my high-boost alarm (which would shortly be followed by fuel-cut) in second gear now, so it's probably time to fit the Thor FCD that's been sat here for a couple of months.
What I want to know is, will the car (UK spec) fuel all the way up to 1.2 bar or will it stop fuelling at the boost level it sees (where the FCD clamps it to).
Does boost have anything at all to do with fuelling or is this taken care of by airflow meters?
If you want to stop fuel cut on a UK spec, take the hose off the MAP sensor and stop it up with a screw. That's it. Of course, that means any overboosting won't be registered, unlike with the Thor unit where it moves the fuel cut rather than removes it.
The UK spec car uses the MAF for all it's fuelling, the MAP is there for one purpose only - to watch for overboost.
On a j-spec it's used for fuelling too, so it's vital. In this case the FCD clips the signal at around 0.99bar of boost as it's only at 1bar+ it initiates fuel cut (it's not a simple switch, cut comes in based on time and level of boost over 1bar but anyway). Fear not about the fuelling because by the time the stock ECU sees 0.9+bar of boost it holds the injectors open 100% anyway. Which on 440's with a decent fuel pump will run 1.2bar of boost on stockers. Seeing as you fuel the same for 1, 1.1, and 1.2bar of boost (100% duty cycle) you may as well run 1.2bar :D
-Ian
-Ian
Very very interesting. Thank you so much Ian :thumbs:
So a J-spec would be running rather rich at 1-bar, and probably about right by 1.2bar (AFR wise anyway). How bizzare. I suppose it's like a desperate safety measure.
Regarding my UK spec, that seems like the preferred solution for me then, since I have a red-light boost alarm on my SPA gauge, and boost-cut is provided by my right foot.
Do people actually *do* this though - block the MAP hose? No cons to it?
  • 7 years later...
