Bleeding Brakes
Geezabloke
Originally posted by Keith C
Removing the trac eh? Hmm, tempting. Tricky to do? I'd quite like to cermoniously burn mine ;)
Best not I guess - so just to be sure, by using traditional 'mate-in-car-with-foot-on-pedal' brake bleeding I don't need to fanny about with the trac system?
Stu - can you remember when you had it done?
yep Keith i'm 95% sure that the brake fluid was changed at the last service the car had shortly before you bought it. I think perhaps only a month or two before. I even took along 2 bottles of new DOT5.1-spec fluid with strict instructions for them to use that. higher spec than Toyota fluid (i think they use DOT4) and also ..... cheaper !
so it had new DOT5.1 fluid at the service shortly before you got it.
cheers
ps. what pads you running these days in it ? and did u change the discs ??
Guest Martin F
You are right, sorry about that.
Just been out to the garage to check the size of my bottles and the're 500ml and i remembered using two. Thought they were 1l.
:stupid:
  • 6 months later...
Ressurrect old thread time again :p
So I take it on the Jspec theres none of this traction control malarky? I can just bleed as normal?
Also, I'm gonna have to drain the system as I'm fitting braided lines at the same time as the UK calipers, is there anything to watch for since it will be all drained (other than make sure all air is out)????
Ta :D
  • 16 years later...
I have rebuilt mh calipers recently (fronts) due to braided lines i clamped flat bar over the banjo end but it still weeped through and the system ran dry. Have tried bleeding a few times but still feel spongy and no feel until half way down. My jspec tt auto has trac and abs so i should follow the tecnique above?
congrats on crazy thread bump ! :)
You have to bleed your master cylinder. easily done . disconnect the lines to the master cylinder/reservoir. have a helper press the brake pedal and hold it down, then block the two holes (where you disconnected the lines) with your fingers and have him release the pedal. Do this til you have no more air coming out. then bleed your brakes as usual.
Thanks dunk, ive seen the manuals being referred to a few times but couldnt find them. Didnt think to look on the main welcome page.
No problem, when we replaced all my brake calipers and brake lines on my UK spec we
bled the system using a Gunson vacuum bleader and had a great pedal straight away
I have an ez bleed but its a pump through the master cylinder type. Doesnt have a fitting for the supra either. Doh!! Anyways thsnks for the help folks, bled the master cylinder as per manual then all 4. Much better pedal, feels more progressive and bites hard around 1/2 travel rather than starting at half pedal. Only issue now ive found the m/c lid wont fit on properly one side always lifts up and can be lifted off with little effort. Have the oem part number 47230, just where to buy? Toyota only?
