suprasport Posted November 14, 2005 Share Posted November 14, 2005 just fitted springs and new wheels took it to be aligned at ATS (good set of lads) said alignment was only out by 1mm so not worth bothering with. but camber as i allready new is a mile out -3 or 4 degrees, but they dont do that told me to use a spirit level and guess, that cant be right surely its more precise than that think it is -1.5 camber, tried moving the cams but they are solid any comments appreciated Quote Link to comment Share on other sites More sharing options...
suprasport Posted November 14, 2005 Author Share Posted November 14, 2005 anybody Quote Link to comment Share on other sites More sharing options...
LeeT Posted November 14, 2005 Share Posted November 14, 2005 ATS are a good set of lads and they told you to guess:eek: they havent got a clue what they are talking about. you need a full 4 wheel laser alignment done professionally. say goodbye to your handling and tyres untill its done Quote Link to comment Share on other sites More sharing options...
suprasport Posted November 14, 2005 Author Share Posted November 14, 2005 yeah to right, just meant they were polite they did the toe and said 1mm out. thought it was supposed to be exact known camber was out since ripping my hands to bits taking wheel off. pulled it off road for now not going anywhere http://www.mkivsupra.net/vbb/showthread.php?t=51799 Quote Link to comment Share on other sites More sharing options...
suprasport Posted November 14, 2005 Author Share Posted November 14, 2005 which one, the supra? oops wrong thread Quote Link to comment Share on other sites More sharing options...
LeeT Posted November 14, 2005 Share Posted November 14, 2005 yeah to right, just meant they were polite they did the toe and said 1mm out. thought it was supposed to be exact known camber was out since ripping my hands to bits taking wheel off. pulled it off road for now not going anywhere http://www.mkivsupra.net/vbb/showthread.php?t=51799 all they have done by the sounds of things is line your front wheels up in relation to the rears which will also be out as you've just lowered it. the four wheel alignment does each corner independently Quote Link to comment Share on other sites More sharing options...
suprasport Posted November 14, 2005 Author Share Posted November 14, 2005 will ask around for someone reputable ready for it being back on the road, a local garage did it as well, paid them but as a favour only charged me for front as i had bought tyres off them wasn't till i got home that i realised they hadn,t charged because they hadnt done Quote Link to comment Share on other sites More sharing options...
Need4Speed Posted November 15, 2005 Share Posted November 15, 2005 You don't give your location. If you're anywhere near Heathrow, PM me and I'll give you a contact. Quote Link to comment Share on other sites More sharing options...
suprasport Posted November 15, 2005 Author Share Posted November 15, 2005 thanks mate but in derbyshire Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted November 15, 2005 Share Posted November 15, 2005 I am about an hour from Donington (East Midlands Airport) and have probably more experience of setting up MKIV suspensions than anyone in Europe. Quote Link to comment Share on other sites More sharing options...
suprasport Posted November 15, 2005 Author Share Posted November 15, 2005 thanks chris, its off road for a while, but i am going to get it something like for now then will get in touch and have a run over to you, few things i wanted to ask you about anyway no one i would rather set it up than yourself quick question though...... cam bolts on lower arm. is one a locking nut? they are solid both sides. wd40'd them to soak Quote Link to comment Share on other sites More sharing options...
