Anyone Seen This - Oil Pressure Weirdness?
tonyhawk
I have an odd problem that's worrying me; I seem to be getting two very different oil pressure readings.
I have fitted a oil pressure gauge using a sandwich plate behind the oil filter, and when the car is warm, the gauge shows about 40psi (give or take), which is fine, but when the engine slows from revving to tickover, the oil pressure light (which is using the standard sensor) flicks on. Odd.
I know the gauge is going to be slower to react than the warning light, but even when the engine burbles at very low revs before picking up for a while(I'm running high lift cams), the gauge doesn't drop below 10psi, and yet the warning light is on?
A few people have said to trust the gauge over the light, but it's still very unnerving to see it come on!
Any thoughts?
