SupraHuman Posted November 13, 2005 Share Posted November 13, 2005 Hi,this is for the tech ppl here. I got a s-afc2 fitted in my J spec soop from back when it was N/A.I am in the middle of fitting my PHR map-ecu(piggy back),my question is, will i have to wire in the AFM in my map-ecu i think it's alredy connected to my s-afc2.I cant find the wire for the AFM on the back of my stock ecu.The map-ecu did come with a AFM sensor.I dont even know if the j spec N/A got a AFM as stock.HELP:cry: Link to comment Share on other sites More sharing options...
Miguel Posted November 13, 2005 Share Posted November 13, 2005 Hi,this is for the tech ppl here. I got a s-afc2 fitted in my J spec soop from back when it was N/A.I am in the middle of fitting my PHR map-ecu(piggy back),my question is, will i have to wire in the AFM in my map-ecu i think it's alredy connected to my s-afc2.I cant find the wire for the AFM on the back of my stock ecu.The map-ecu did come with a AFM sensor.I dont even know if the j spec N/A got a AFM as stock.HELP:cry: The map ECU was designed to eliminate the use of the Air flow meter converting it to MAP if that is what you are asking. Link to comment Share on other sites More sharing options...
LeeT Posted November 13, 2005 Share Posted November 13, 2005 The map ECU was designed to eliminate the use of the Air flow meter converting it to MAP if that is what you are asking. so stick with the safc2 and give the MAPECU to me:) Link to comment Share on other sites More sharing options...
bromy Posted November 13, 2005 Share Posted November 13, 2005 Your turbo kit can be run with the safc, it will only be worthwhile wiring in your map ecu piggyback if it came with a pressure sensor (map sensor) Link to comment Share on other sites More sharing options...
SupraHuman Posted November 13, 2005 Author Share Posted November 13, 2005 Your turbo kit can be run with the safc, it will only be worthwhile wiring in your map ecu piggyback if it came with a pressure sensor (map sensor) Thanks all. yeah bromy the map-ecu did come with a pressure sensor so it's now connected to the new map-ecu.just the piggy tails left to do. cheers Link to comment Share on other sites More sharing options...
SupraHuman Posted November 13, 2005 Author Share Posted November 13, 2005 so stick with the safc2 and give the MAPECU to me:) errrrr.i think maybe....NOT.... Link to comment Share on other sites More sharing options...
