penguin Posted November 12, 2005 Share Posted November 12, 2005 Hey, ok, so i managed to get the bits i need to recondition it from toyota... and now i've found the starter... the 2 bolts that hold it down are IMPOSSIBLE to unscrew .... i've tried from the bottom of the car/top etc,... can anyone share experiances and whats the best way of doing it? any specific spanners etc ? im in deep, as the car is on my drive - and not able to go anywhere - she wont even fire up j-spec tt auto ta penguin:violin: Link to comment Share on other sites More sharing options...
TrickTT Posted November 12, 2005 Share Posted November 12, 2005 14mm socket and long(at least 2 foot) wobble bar from underneath. Use 3/8th drive preferably with a ratchet. Link to comment Share on other sites More sharing options...
Jake Posted November 12, 2005 Share Posted November 12, 2005 Exactly what trick152 said. It's a fairly easy job if you've got the car off the ground on axle stands or preferably a ramp. Link to comment Share on other sites More sharing options...
penguin Posted November 12, 2005 Author Share Posted November 12, 2005 after nearly 8 hours its off...... question now is... er... which bits do i need to "recondition"? i have the starter assembly kits #28226-74070 and 28226-22050... would love to have a numptys guide (i'm going to write one up with pictures to assist future home mechanics ) Thanks folks *EDIT* : managed to get the figure below... Link to comment Share on other sites More sharing options...
penguin Posted November 12, 2005 Author Share Posted November 12, 2005 really need help here dude(ette)'s Link to comment Share on other sites More sharing options...
TrickTT Posted November 13, 2005 Share Posted November 13, 2005 Undo the five sided cover ( carefully, its got a spring inside). The two kits you have correspond to the contacts on either side of the solenoid. Take the old ones off carefully, noting the order of the bits, then replace with new. Clean the copper ring on the plunger carefully with a file (i used the wifes metal nail file - she was not happy - but it works), then put it all back together. Link to comment Share on other sites More sharing options...
penguin Posted November 13, 2005 Author Share Posted November 13, 2005 Big THANK YOU to Trick152 & Jake ... i did f-up but will post a more detailed analysis this evening... going to put the starter back in the car now Link to comment Share on other sites More sharing options...
SUPRALOOPY Posted November 13, 2005 Share Posted November 13, 2005 just done a how to have a look Link to comment Share on other sites More sharing options...
Branners Posted November 13, 2005 Share Posted November 13, 2005 once its back in and working can you post up the details of the exact part numbers you ordered from Toyota as Phoenix arent sure if the 2 part numbers I have them will be sufficient to refurb it all. thanks JB Link to comment Share on other sites More sharing options...
SUPRALOOPY Posted November 13, 2005 Share Posted November 13, 2005 this sorted it for me... 28226-74070 28226-22050 all about 15 quid all in:D better than a new starter as they tried to sell me £400ish Link to comment Share on other sites More sharing options...
Branners Posted November 13, 2005 Share Posted November 13, 2005 Phoenix said those two parts may not be enough, I gave them the part numbers and everything. The car is due with them some time this week so lets see what happens. JB Link to comment Share on other sites More sharing options...
SUPRALOOPY Posted November 13, 2005 Share Posted November 13, 2005 Phoenix said those two parts may not be enough, I gave them the part numbers and everything. The car is due with them some time this week so lets see what happens. JB cos i was told i needed a new starter. but the car would start after a bit of clicking..when i took the starter apart it was obvious what was causing the problem..so if your car clicks when cold then starts the starter is ok imo and its just the contacts..when i took mine apart you could see that one of the contacts was worn out, there was a big groove in the contact plate and the throw part was all dirty. Link to comment Share on other sites More sharing options...
Branners Posted November 13, 2005 Share Posted November 13, 2005 mine just clicks and wont start at all not matter what I do. The car has 130,000 on it so its highly likely that its shot but will let Phoenix take a look later this week. JB Link to comment Share on other sites More sharing options...
SUPRALOOPY Posted November 13, 2005 Share Posted November 13, 2005 mine just clicks and wont start at all not matter what I do. The car has 130,000 on it so its highly likely that its shot but will let Phoenix take a look later this week. JB if this is gonna cost you doe, take you starter out and have a look i bet its just the parts i have replaced..see my how to as looking at how its all built there is not alot to go wrong with the machanics of the starter:whistle: jmo though. Link to comment Share on other sites More sharing options...
penguin Posted November 13, 2005 Author Share Posted November 13, 2005 MUHAHAHAHAHAHAAHAHHAHAHA Shes ALIVE Thank you for everyones useful advice - i love this place. Branners, http://www.mkivsupra.net/vbb/showthread.php?t=51682 if its "click click"... deffo the starter contacts... part numbers on above link Link to comment Share on other sites More sharing options...
Jive Posted November 22, 2005 Share Posted November 22, 2005 mine just clicks and wont start at all not matter what I do. The car has 130,000 on it so its highly likely that its shot but will let Phoenix take a look later this week. Branners, did you get your car fixed with the solution mentioned here? I used it over the weekend and it's worked a treat and my car sounded exactly the same as yours .. except it would fire every now and then. Just like to say a big thanks to Supraloopy for the solution Link to comment Share on other sites More sharing options...
Branners Posted November 22, 2005 Share Posted November 22, 2005 yes, those parts did fix the problem. Phoenix did all the work on it for me so I obviously had to pay labour as well but it seems a bargain compared to using a new or recon starter. Thanks for the part numbers people, saved me a fortune. JB Link to comment Share on other sites More sharing options...
Jive Posted November 22, 2005 Share Posted November 22, 2005 Out of curiosity, how much did they charge you to do that job? Roughly if you don't want to commit to it Link to comment Share on other sites More sharing options...
Branners Posted November 22, 2005 Share Posted November 22, 2005 not sure if it was a special price but it was 1.5 hours worth of labour and £13 worth of parts. Total bill was £76. JB Link to comment Share on other sites More sharing options...
Jive Posted November 22, 2005 Share Posted November 22, 2005 Cool, probably took us about 1.5 hours as well, although 1 hour was spent getting the top bolt off Cost me £18 so well worth it and you've got a bargain as well Link to comment Share on other sites More sharing options...
