dannyspeed Posted November 12, 2005 Share Posted November 12, 2005 ive noticed for the last couple of weeks that when the second turbo kicks in under full accelaration the power delivery aint smooth it starts missfiring i think and i noticed white smoke when this happens. It runs perfect appart from this. i had the car serviced by a garage i know quite well last week and i thought that might solve the prob but it aint. ive got a blitz nur spec with one cat removed and HKS spark plugs as the only mods to the engine. any ideas would be great ive read aerotop daves thread but not sure its the same prob as it happen hot or cold. . Quote Link to comment Share on other sites More sharing options...
bignum Posted November 12, 2005 Share Posted November 12, 2005 sounds like plug gaps m8 Quote Link to comment Share on other sites More sharing options...
dannyspeed Posted November 13, 2005 Author Share Posted November 13, 2005 Not sure that could be the prob as its only started happening over the last month or so and the spark plugs have been in the car for about 2 years. Anyone got any other suggestions? Quote Link to comment Share on other sites More sharing options...
Clarkey Posted November 13, 2005 Share Posted November 13, 2005 the spark plugs have been in the car for about 2 years. Time to change the plugs! Quote Link to comment Share on other sites More sharing options...
Soop Dogg Posted November 14, 2005 Share Posted November 14, 2005 Quote Link to comment Share on other sites More sharing options...
dannyspeed Posted November 14, 2005 Author Share Posted November 14, 2005 how often should the plugs be changed? ive got hks iridium plugs. Quote Link to comment Share on other sites More sharing options...
Steve Posted November 14, 2005 Share Posted November 14, 2005 Have a read of this mate. Iridiums approx 30,000 miles according to this thread. http://www.mkivsupra.net/vbb/showthread.php?t=41927 Quote Link to comment Share on other sites More sharing options...
dannyspeed Posted November 16, 2005 Author Share Posted November 16, 2005 thanks smarty for the link. Well ive only done 10-15k on the iridium plugs over 2 years but its been driven quite hard, santa pod and seeing how far the speedo will go round on the m1 ect. Does anyone think changing the plugs will solve the problem and is there anyway to know for sure ie any tests that the spark plugs have had it? Or shall i just change the spark plugs and see will it solve the problem? Quote Link to comment Share on other sites More sharing options...
Nic Posted November 16, 2005 Share Posted November 16, 2005 I change my HKS plugs every 10,000km, I think you'll find this is the reason for the hesitation problems you're having. Quote Link to comment Share on other sites More sharing options...
SteveL Posted November 16, 2005 Share Posted November 16, 2005 Sounds like a proble I've had for a while.... Changed plugs, resistor packs, new connectors on the packs. Tried all the diagnostic attempts on the twin setup, ran in TTC, changed hoses... still can't find the bugger. Only thing I can assume is that my pressure tank is loosing pressure between boosting. Do you get the same? if you stay on boost/boost often all is well, stay off boost for a couple of mins and the first full boost 'misses' then kicks in? Steve. Quote Link to comment Share on other sites More sharing options...
dannyspeed Posted November 19, 2005 Author Share Posted November 19, 2005 It just seems to missfire every time 2nd turbo kicks in on full boost if i only floor it 70-80% and the 2nd turbo kicks in its fine. Il change the spark plugs as it sound like thats the prob. cheers guys. Quote Link to comment Share on other sites More sharing options...
