Front decat stud snapped :(
jaymdee
Hi all,
Noticed my exhaust seemed to blowing a bit so have just got home fom the garage where we looked at it.
It seems that when my car was rear-ended a while back, the bottom of the three studs which bolts the 1st CAT removal pipe to the turbo elbow has snapped, causing the blowing. The guy in the garage says he can remove the stud, retap the hole and restud it.
How easy is this? Obviously the elbow needs to be removed fom the Turbo. Is this easy, or can these studs/bolts snap too, causing a bigger problem?
Or, is it easier/cheaper to get a new elbow?
I'm sure loads of people must have had snapped studs on their decats, any advice?
cheers
J
My bolts snapped too! Don't worry. The garage man should be able to do it. He will either drill and re-tap or drill and place a slightly thinner but still strong nut and bolt on for you. I was stressing big time so don't worry be happy....
Cheers for the encouragement there guys,
I'm going to speak to the Insurance Co again (Sky) as this must have happened in the shunt, and is only manifesting itself now - so surely the other guys insurance should pay for the repair. (I even stated I was worried that this may have happened and was told all was fine??)
J
