Pete Posted November 12, 2005 Share Posted November 12, 2005 ....or maybe I should give the car to Thor for a v8 conversion It would make more financial sense to get the VVTi running and swll this car as a VVTi spec, then get another (much cheaper) and then convert? Link to comment Share on other sites More sharing options...
Lazarus Posted November 12, 2005 Share Posted November 12, 2005 Thats some really bad luck Jake. How many miles were on this engine? from new and since fitting, was it standing for a while before you fitted it? What did you have done to the motor before you fitted it? or did you just lob it in thinking it was a good'un? Sorry for the Questions, but it might help nail down the cause. Link to comment Share on other sites More sharing options...
Kopite Posted November 12, 2005 Share Posted November 12, 2005 Gutted for ya dude, that car's jinxed! Good luck with it though Link to comment Share on other sites More sharing options...
Jake Posted November 13, 2005 Author Share Posted November 13, 2005 How many miles were on this engine? from new and since fitting, was it standing for a while before you fitted it? What did you have done to the motor before you fitted it? or did you just lob it in thinking it was a good'un? It's the engine from Rob Oldham's crashed car. I got it from a car breaker up Cambridge way. It had been there for about a year. Rob said it had only just done over 30,000 miles, had had regular oil changes and was running great at time of the crash. It was complete apart from the turbos when I got it. All I did was fit some low milage turbos from TDaxGav and put it in the car. I checked the plugs and the oil, hoovered the broken glass out from inside the spark plug cover and started her up. It seemed to run fine. I'd only taken it out for a 10 mile test drive once because the car has no MoT. Link to comment Share on other sites More sharing options...
JohnA Posted November 13, 2005 Share Posted November 13, 2005 Had you flushed the cooling system? Was the radcap original and in good condition? were the hoses nice and tight? Link to comment Share on other sites More sharing options...
Jake Posted November 13, 2005 Author Share Posted November 13, 2005 I didn't flush it, just filled it with water and antifreeze. The rad and cap were the ones originally fitted to the car. The water seemed to have come out through the rad cap. The expansion tank is still half full Link to comment Share on other sites More sharing options...
SkyJawa Posted November 13, 2005 Share Posted November 13, 2005 Bloody hell Jake What an arse mate Hope you get it sorted quickly and as least wallet damaging as poss mate Link to comment Share on other sites More sharing options...
Lazarus Posted November 13, 2005 Share Posted November 13, 2005 It's the engine from Rob Oldham's crashed car. I got it from a car breaker up Cambridge way. It had been there for about a year. Rob said it had only just done over 30,000 miles, had had regular oil changes and was running great at time of the crash. It was complete apart from the turbos when I got it. All I did was fit some low milage turbos from TDaxGav and put it in the car. I checked the plugs and the oil, hoovered the broken glass out from inside the spark plug cover and started her up. It seemed to run fine. I'd only taken it out for a 10 mile test drive once because the car has no MoT. Did you see the engine before it was pulled from Rob's old car? Was the coolant system intact for the year that the motor was laid up? I ask because if the coolant system was open to atmosphere for that long then the coolant remaining in the block would evaporate off and the Glycerine in the antifreeze would start to crystalize and form blockages in the narrower passages of the water jacket. Even when a breakers yard drains a system (like there supposed to according to current legislation) there's no garantee that some coolant isn't retained with-in the block, they normally just remove the bottom hose from the rad (or put a knife through it). Just a thought.... (which is largely immaterial as none of that above actually helps you to get your car fixed) Link to comment Share on other sites More sharing options...
Gaz Walker Posted November 13, 2005 Share Posted November 13, 2005 Nightmare Jake... that should be your bad luck over though. The futures bright, the futures... Supra Gaz. Link to comment Share on other sites More sharing options...
toyotasuprauk Posted November 13, 2005 Share Posted November 13, 2005 If I was Jake the future would quite firmly not be Supra! I really hope you can sort this ok Jake. Link to comment Share on other sites More sharing options...
Jake Posted November 13, 2005 Author Share Posted November 13, 2005 I'm just trying to decide what to do now. Do I strip the head off myself and see if the pistons and bores are damaged, or do I send the car to somewhere like CW or Phoenix and ask them to do it? I really don't fancy taking the stock turbos off just so I can pull the head but being unemployed I've got the time. If it turns out to need a rebore, new pistons, bottom end, etc etc it's going to be hugely expensive but what can I do? I can't scrap a ten grand car. I'm guessing the chances of me finding another VVTi engine are about zero. Bloody cars. Link to comment Share on other sites More sharing options...
Steve Posted November 13, 2005 Share Posted November 13, 2005 I'm just trying to decide what to do now. Do I strip the head off myself and see if the pistons and bores are damaged, or do I send the car to somewhere like CW or Phoenix and ask them to do it? I really don't fancy taking the stock turbos off just so I can pull the head but being unemployed I've got the time. If it turns out to need a rebore, new pistons, bottom end, etc etc it's going to be hugely expensive but what can I do? I can't scrap a ten grand car. I'm guessing the chances of me finding another VVTi engine are about zero. Bloody cars. Go for it mate. Will be cheaper to pull the head off yourself rather than taking it somewhere and paying an hourly rate. Link to comment Share on other sites More sharing options...
Miguel Posted November 13, 2005 Share Posted November 13, 2005 I'm just trying to decide what to do now. Do I strip the head off myself and see if the pistons and bores are damaged, or do I send the car to somewhere like CW or Phoenix and ask them to do it? I really don't fancy taking the stock turbos off just so I can pull the head but being unemployed I've got the time. If it turns out to need a rebore, new pistons, bottom end, etc etc it's going to be hugely expensive but what can I do? I can't scrap a ten grand car. I'm guessing the chances of me finding another VVTi engine are about zero. Bloody cars. Tune the cods of it ...good excuse to build a sweet lump. Link to comment Share on other sites More sharing options...
Marco Posted November 13, 2005 Share Posted November 13, 2005 I know how you feel Jake. You don't want to sell a good running car, but can't sell a broken one... Happened to me when the turbo's broke, and then a second time. Only thing to do is put some more money into it :thumbdown Link to comment Share on other sites More sharing options...
Jake Posted November 13, 2005 Author Share Posted November 13, 2005 Tune the cods of it ...good excuse to build a sweet lump. I don't want to tune that one Mig, I want to sell the sodding thing. It was going to be put up for sale once it had passed its MoT. I was just reading this thread by Foodfreak. It seems that he's had a new short engine fitted by Phoenix. Does that mean the VVTi uses the same short engine as the pre-vvti? If so that'll make it a lot easier for me to find another lump. I wonder how much a new short engine costs and how much Phoenix would charge for fitting it. Link to comment Share on other sites More sharing options...
Miguel Posted November 13, 2005 Share Posted November 13, 2005 Bottom end is exact the same as non VVti. Or sell it as it is for me to play with:ecstatic: Link to comment Share on other sites More sharing options...
Jake Posted November 13, 2005 Author Share Posted November 13, 2005 What's it worth though? I'd like to get 10k for it when it's fixed but I could be very tempted to just cut my losses, sell it and buy that black one at Phoenix - if it's still there. Whose car is that anyway? Not your old one is it? Link to comment Share on other sites More sharing options...
TLicense Posted November 13, 2005 Share Posted November 13, 2005 I wonder how much a new short engine costs and how much Phoenix would charge for fitting it. You can buy a brand spanker from MVP and have it delivered for approx £1300. To buy one here from Mr T is £1800 + VAT Link to comment Share on other sites More sharing options...
Miguel Posted November 13, 2005 Share Posted November 13, 2005 What's it worth though? I'd like to get 10k for it when it's fixed but I could be very tempted to just cut my losses, sell it and buy that black one at Phoenix - if it's still there. Whose car is that anyway? Not your old one is it? Yup. Link to comment Share on other sites More sharing options...
Jake Posted November 14, 2005 Author Share Posted November 14, 2005 You can buy a brand spanker from MVP and have it delivered for approx £1300. To buy one here from Mr T is £1800 + VAT Seems it's a little more than £1300 actually Tony. Dusty quoted me $2329 + $399 delivery. Thats $2728 or £1566 at the current exchange rate. Link to comment Share on other sites More sharing options...
TLicense Posted November 14, 2005 Share Posted November 14, 2005 Really?? Hmm I must be on drugs or something. I'm sure he quoted me less than that? Didn't you promise to give him head? You should know by now.... To be honest perhaps I got it wrong. I have got the e-mail abouts here somewhere but it's on a hard-disk that's got a corrupt OS on it. Still £1566 is still alot cheaper than £1800 + VAT! Link to comment Share on other sites More sharing options...
Jake Posted November 14, 2005 Author Share Posted November 14, 2005 Didn't you promise to give him head? I didn't, but for £266 I would do it. Link to comment Share on other sites More sharing options...
Miguel Posted November 14, 2005 Share Posted November 14, 2005 I didn't, but for £266 I would do it. Really hmmmm, wana job Link to comment Share on other sites More sharing options...
Guest begone Posted November 14, 2005 Share Posted November 14, 2005 Man that sucks. Sorry to hear about your troubles. That makes me want to upgrade my Radiator Pronto. I'm still running my NA Radiator. I figured I'd wait till it blew and just keep a close eye on the Temps, but aparently there was no Warning signs. So do you think it was the HG Blowing first, or the Heat from a bad radiator that caused the HG to blow? Link to comment Share on other sites More sharing options...
Miguel Posted November 14, 2005 Share Posted November 14, 2005 Just thought of something, Was the car not involved in a roll over? Was the car left upside down running? If it was then she would have been running with no oil pick up for however long until it was shut down..Just a thought thats all. Is the water pump OK? Link to comment Share on other sites More sharing options...
